   / Share Pics of People Hauling or Towing Something Wrong #3,981
That's the nice thing about the protector sleeves, I linked to above, is that they slide onto the straps and can't come off. I have tried all of the plastic crap and sleeves are better IMHO. Put straps in place, semi tight, slide sleeves onto hard corners, finish tightening down straps. Boom!
   / Share Pics of People Hauling or Towing Something Wrong #3,982
I use old conveyer belt, works well moving machining equipment.
   / Share Pics of People Hauling or Towing Something Wrong #3,983
I use whatever this guy uses.
Tapatalk Cloud - Downlaoad File 211-3-7%213.27.42-1
   / Share Pics of People Hauling or Towing Something Wrong #3,984
Its political season, collect those plastic cardboard political signs after election day and use those. They should hold up better than cardboard.
Aaron Z
Those are in good supply around here. :thumbsup:
   / Share Pics of People Hauling or Towing Something Wrong #3,985
I won't use straps for securing a load when they cross an edge, I had a long block on a pallet secured with straps, by the time I got home, two of the straps were cut where they touched an edge. if the straps are tight (like they should be), there is usually enough movement to quickly "saw" through or at least weaken the strap.
Make sure each section of strap, where it is not in contact with anything, has at least a half spin in it. You don't want any straight straps. This breaks up the airflow and prevents the whipping that you often see on straps.
That's a trick I leaned from a young trucker friend. I've been using it ever since, and I don't have whipping straps and I don't have cut straps.
   / Share Pics of People Hauling or Towing Something Wrong #3,986
   / Share Pics of People Hauling or Towing Something Wrong #3,987
I won't use straps for securing a load when they cross an edge, I had a long block on a pallet secured with straps, by the time I got home, two of the straps were cut where they touched an edge. if the straps are tight (like they should be), there is usually enough movement to quickly "saw" through or at least weaken the strap. I continue to buy straps for some reason, like when we drove 280 miles to get our new mower and realized all the straps/chains/etc were in the truck and not the Tahoe we took. Tied it down best we could, drove very slow to the local NAPA store and bought a 4 pack of straps. NO edges were crossed, held up very nice, even had a panic stop and the 1154lb mower did not shift. I have a toolbox that I am going to mount on the trailer tongue that will have an assortment of straps and chains. Just have not done it yet..
that's why you use corner strap protectors.. you can buy them.. or make them fro a piece of carpet.. etc. not rocket science...
   / Share Pics of People Hauling or Towing Something Wrong #3,988
Why? to be mean?
that's what's wrong with america.. not the guy hauling his bed the only way he can.. it's the next guy that wishes trouble on him. :(
Here here! :drink:
   / Share Pics of People Hauling or Towing Something Wrong #3,989
   / Share Pics of People Hauling or Towing Something Wrong #3,990
Aaron Z
That is, until you remind them of the promises they made during the campaign. After that they just "fall to pieces."
2020 POLARIS RANGER 1000 RTV (A52708)
2020 POLARIS...
TPM RM900SB All Terrain Remote Controlled Weed and Brush Mower (New/Unused) (A59225)
TPM RM900SB All...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
