Help selecting a Post Driver
/ Help selecting a Post Driver #21
I can't speak for the 3-point mount itself, but everything from the manual adjust to the pounder itself looks identical on the Kencove to the Shaver. 99.99% sure it's the same driver.
As a side note, I ended up purchasing a used Shaver when I found it for a good price - HD10 with 3-point and SSQA mounts in good condition with full hydraulics for $1500. They do come up here and there on Craigslist. The few questions I've asked Shaver they have been really nice to deal with... seems like a stand-up company.
/ Help selecting a Post Driver #22
$23 a post!? Holy cow. Was that just labor? 3 board fence I'm lucky to get $10-11/ft for everything.
I think the best way to do it is to add the power beyond plug into the post pounder's valve, and then run it back into the remote. That way the pump is never dead-headed, the fluid is constantly flowing.
This sounds like a good plan. I haven't seen it mentioned in my previous wanderings through other tractorbynet post driver discussions.
What is needed to implement this? Is there an output plug on the post driver valve that would get replaced with some type of power beyond adapter plug? A new line would then get run from the power beyond adapter on the post driver back to my tractor's rear remote?
Maybe I'll keep an eye out for a little while before pulling the trigger on a new one. At the current time I could only fine one within 2 hours of my home. The seller was asking $3K, and it looked like it had been out in the weather quite some time.
/ Help selecting a Post Driver #24
Using a power beyond port as a return on a Shaver valve set as an open center valve is needlessly redundant. The valve is open center, return flow when the valve spool is centered is open via the zero pressure return connection. The only time the flow is deadheaded would be if you held a spool in lift position with the cylinder fully extended.
I'm not sure what your $10-$11/ft includes, but is how my quote worked:
Full fencing (lumber AND labor) was $2.80/ft for boards and $4.80/ft for posts ($7.60/ft total). I've got about 1100 feet of fencing to do. That's $5280 lumber and labor just for setting the posts. Over 1100 feet is roughly 142 posts (spaced @ 7'9"). Cost of posts is ~$12 per post which is about $1704 for the lumber (posts only). So, $5280 minus $1704 is $3576 in labor for setting the 142 posts. That's equates closer to $25 in labor per post.
My father-in-law paid $14 per post from the same contractor about a month earlier. When I questioned the contractor, he said that the work quoted for my father-in-law was very low. I guess I was getting the "We don't need the work" price...
So, when I saw that a post driver was about $4000 new and labor for someone to do the work was $3600, it go me thinking. ...and since I have about another 2200 ft of fencing to do in the year or so, the post driver option started to make sense.
/ Help selecting a Post Driver #26
4x4 on 7' centers. 80 bag of sackrete/post. 3 2"x8"s and a 2x4 nose board. Hot dipped GRS. Materials and labor. Gate posts are 6x6 with 3 bags sackrete. Where do you live?
/ Help selecting a Post Driver #27
If it's open center, yes... I believe the default is closed center though. That's how mine was at least.
/ Help selecting a Post Driver #28
They ship open center. If you need CC an optional CC plug needs to be ordered.
Power Beyond isn't needed in a CC system. You simply tee the supply line to however many valves are present.
/ Help selecting a Post Driver #29
I took a look at these. You ca get a skid steer adapter for the Shaver as well. Unfortunately, I only have lift and tilt control on my FEL, so I would have to plumb another supply and return line up front. On the back end I already have a rear remote that I can hold open as a supply and I would only need to route a return line. Although I'm not sure how best to route the return on my Kubota just yet, so that might be just as much work.
The clamp and tilt functions are part of the control package on the Danseur. I believe all you need is a 12 VDC power supply for the selector valve.
I'm in Gloucester County in South Eastern, VA. My quote only included concrete on the gate posts which were also 6x6s. Corner posts were 6x6s, but no concrete. The board portion of the quote included rough cut 1x6x16's. The line posts were rough cut 4x4s.
/ Help selecting a Post Driver #31
How straight can they get a line using a driver. The ones I've looked at and liked were $15-20k. They had tilt offset and and an auger. I've been putting up fence off and on for 33 years. Like you said using a tamp all day hasn't done a lot for my joints. And using a driver would mean no 80lb bags of sackrete/hole which I could drop my price $1/ft just in material.
/ Help selecting a Post Driver #32
Just to be clear... because I am a hydraulics idiot... since the control valve is open center, if the valve is left in the center/neutral position, flow will continue through the valve straight to the return/drain line back into the transmission?
Since the nature of a post driver is to fully extend the cylinder for a very short period over and over and over, could the constant short period of deadheading accumulate to result in any sort of damage to the system over a prolonged period of usage. As a minimum is sounds like the recommendation would be to never hold the cylinder in the fully extended period since there is noting to act as a bypass valve?
I'm still curious... is a special adapter needed to converter an output port on the valve to a power beyond port? Would that then act as a bypass valve if the cylinder is held in the fully extended position (either plumbed using the two sides of a rear remote or plumbed by a formal power beyond port on an FEL valve)?
Thanks so much everyone for all the great information!!! This thread has been a great source of info for much more than just the post driver itself. :) :thumbsup:
/ Help selecting a Post Driver #34
The Shaver I used had a supply line under pressure and a big return line that was plumbed directly into the fill port of the transmission. I got a nipple from the hardware store that I adapted to the return line from that hydraulic ram of the driver. That was something like a 1" return line. I used a dump port (not the lift port) of the 4 lines for the front end loader. I pulled the loader control using a bungie cord which supplied me with plenty of fluid back at the driver. You pull the driver one direction to lift it. Push the other to let it slam down. Up and down. I recall 3 minutes a post to pound a 4/4 post pointed with a chainsaw. Moist red clay of Georgia.
The driver I used had a control valve which was a dead end if I recall correctly. Then again it has been 19 years since I did my over 500 fence posts set 8' on center. The posts are pretty straight even after 19 years. Pretty plumb too. Well good enough. Too dark to take a picture.
You have read the owners manual? http://www.shavermfg.com/media/uploads/HD8-Operator-Manual.pdf The controls are not the same as the now 30 year old driver I was using.
/ Help selecting a Post Driver #35
Yes.
No.
Yes.
No.
No.
/ Help selecting a Post Driver #36
Yeah, you're fine if the valve is open center.
Yes.
No.
Yes.
No.
No.
LOL! Thanks for the answers! :laughing:
Actually shouldn't the main relief valve (in my tractor I think it's in the main FEL valve block) come before all the cylinders in the system (even before the rear remote which I'll used to supply the driver), so that the relief valve would still actuate even if the post driver was held in the fully extended position for a period of time? This would be similar to over extending the FEL in any of its four positions when you can hear the whine as the relief valve opens. I think in the L4400, the FEL valve block is first in the system, then anything on the power beyond, and finally the 3pt hydraulics and rear remotes.
...I did find the video below to be very helpful in getting a better general understanding of the system. It just took a little bit of time to learn all the hydraulic circuit symbology.
How to Use the Power Beyond Facility in a Hydraulic Directional Control Valve (with improved audio) - YouTube
This is all starting to wander a bit off of the original topic, but I think it's all related information if anyone comes searching in the future.
/ Help selecting a Post Driver #38
Just to be clear... because I am a hydraulics idiot... since the control valve is open center, if the valve is left in the center/neutral position, flow will continue through the valve straight to the return/drain line back into the transmission? [1]
Since the nature of a post driver is to fully extend the cylinder for a very short period over and over and over, could the constant short period of deadheading accumulate to result in any sort of damage to the system over a prolonged period of usage.[2] As a minimum is sounds like the recommendation would be to never hold the cylinder in the fully extended period since there is noting to act as a bypass valve?[3]
I'm still curious... is a special adapter needed to converter an output port on the valve to a power beyond port?[4] Would that then act as a bypass valve if the cylinder is held in the fully extended position (either plumbed using the two sides of a rear remote or plumbed by a formal power beyond port on an FEL valve)?[5]
Yes.
No.
Yes. why?
No.
No.
The valve is holding the lift pressure when the lever is centered; not the pump. ... Bypass - if the lever is held operated for some reason - goes through the tractor pressure relief.
/ Help selecting a Post Driver #39
True. My answer was specific to the Shaver valve alone; with or without the PB circuit as discussed. The tractor system relief is the protection.
Thanks for the help. I think this covers my last question, and I think I'm now in pretty good shape. I'm just gonna keep my eyes on Craigslist for a little while to see if I can find a deal. If I run out of patience, then I'll pull the trigger on the new post driver. It might be a bit dry now anyway. I'm thinking that, in my area of VA, fall will probably be a good time to put in some posts.
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63689)
2019 Cadillac XTS...
ATS ATS-PC90 Heavy Duty Plate Compactor (A62679)
ATS ATS-PC90 Heavy...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
2018 FORD F-150 (A65643)
2018 FORD F-150...
Dueling Tree (A65640)
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
