Tractor tipping point
   / Tractor tipping point #21
If your tractor has a ROPS, wear your seat belt.
You are right to be very concerned on hills of any degree or angle. If you have only rear drive, then you have only rear brakes. If you have mfwd, and are in rear only drive, then you still only have rear brakes. This becomes much more evident with a loader.
The maths involved with the actual tipping point and any tractor will involve not only the cog, but the location of the front axle pivot, both length from the rear tire contact with the surface, and the height upward from the surface.
If you are running an old tractor without rops, and are not experienced, or even if you are, and working on hills, always tell someone where you will be and when you will be there. If possible, have someone there with you. More people are found dead under a tractor or in the bottom of a ravine, but only after several hours had past since they were supposed to be home for dinner.
   / Tractor tipping point #22
I understand better the cog with an implement on uphill or downhill how it can affect it but I do have a question: lets take a backhoe with outriggers. (Not saying this is proper operation but best way to ask my question.) You lower the downhill outrigger where it is say 6 inches off the ground. Now do you use the low side tire to determine the cog or do you use the outrigger to determine it? Is the outrigger not of benefit to help stop a rollover? Or would running out the uphill outrigger the same amount be of greater value?
The center of gravity hasn't really moved much, but what the outrigger did, same as the boom on the excavator, is to move the fulcrum away from the down hill side track or wheel, out to the end of the outrigger. The backhoe would have to tip far enough to lift the entire tractor off the ground. The fulcrum could be drawn in a straight line from the end of the outrigger to the outside of the front bucket (assuming it is on the ground). The center of gravity would have to cross this line in order to cause a roll.
Again, it isn't the weight of the outrigger, it is the leverage that is beneficial. The weight of the outrigger is probably negligible compared to the whole backhoe.
Side mount cutters bolted to the frame would probably offer some leverage in a crisis. A 3ph mounted one, not so much. There are very few tractors that offer power down on the 3ph, so it could just raise up (as well as maybe swing side to side uphill).
   / Tractor tipping point #23
There are alot of variables, even on similar tractors. Do you have a front loader? Do you have fluid filled tires? What type of implements are you running? I would look into ROPS for that specific model if not installed already. I come from a little different world where I operate equipment big enough a side mount, or a sickle bar or disc mower isn't beefy enough if the rig starts to go it would fold it like wire.
   / Tractor tipping point #24
there is no magic number for how much of a slope you can run on. a sickle mower or disc mower will not provide any help from a roll over, they have a pivot point. best advice get some seat time before getting on a slope
   / Tractor tipping point #25
I live on top of hill. Rollovers are the biggest thing I fear when I'm on my hill, especially when I'm bushogging, even though I go straight up and straight down.
Things I've done to prevent rolling over:
- Filled all four tires. Yea, only the rear ones help preventing rollovers, but filling the fronts aided in front traction going up my hill.
- Widened the rear tires as far as possible. Worth every penny of the $150 it cost me.
- Added lead, steel and concrete wheel weights to the rear tires and wheels; added 500 lbs.
- Added steel and concrete weights to the torque tubes of the FEL. About 80 lbs total for both of them; not a lot but it's down low and every bit helps.
- Added rail "fishplates" to the front bumper. Some of them are higher than the CG but most are below where I think the CG is.
Finally, I did roll over my RTV this last Sunday. Running a sidehill (normal trail was blocked) and hit a fallen (and hidden log). The front wheel bounced and my foot hit the accelerator; the rear bounced and over she went in a slow motion roll over. Tipped her back over and towed her home. Left it for two days and it started up fine. A bullet dodged there.
   / Tractor tipping point #26
I find my B7200 with turfs set to the widest position to be a lot more stable on hills than my larger tractors with a loader. The finish mower also helps a lot since it's mounted low. My F-2560 is the most stable going across hills, but it has terrible traction going up hills. I've never met a hill the B7200 wouldn't climb. I've rode up hills on 2 wheels with the finish mower preventing a rollover. The F-2560 gives up pretty fast.
   / Tractor tipping point #27
Experience is the best teacher as long as you stay on the safe side. The little SCUTs like my BX are especially vulnerable even though they have a low CG due to small tires. The wheel spacing is pretty narrow which compounds the situation and the tires are so small loading with fluid is negligible. I use suitcase weights w/custom fabbed mounting brackets for both front and back. There have been a lot of posts here on turning over SCUTS. My dentist has a B 2--- which is not much bigger and he has turned it over 3 times in 250 hours. I accused him of being a hot rodder. I have 1500 on my BX and have never turned it over and most of my work is on slopes moving logs and brush loads at FEL max. I spent a lot of time experimenting with how to best work on slopes. I have had my BX on one wheel several times. For and old man my reflexes and situational awareness are pretty good. My head is moving and looking at the terrain and my tractor's reactions.
To add to the discussion on ballast weight on upper or lower side; I did a lot of experimenting with the back hoe mounted and using it as a moving ballast. I found my maximum stability at a mid boom angle W/bucket curled back and hoe turned to the up hill side. Most of the theory expounded is beyond my comprehension so I go with my gut. Worked do far.
I put a lot of my success on moving slow and slower!!
Ron
   / Tractor tipping point #28
Hi Julian, and welcome to TBN. :D
I must say I'm quite impressed with your choice of tractor - you should be happy with it, and with some experience will be driving it with steadily-increasing confidence. :thumbsup: Mine are just a bit older :laughing: But stay within your depth - we certainly don't want any bad news! ;)
I just read this whole thread and agree with the opinions posted. There's a heap of good advice there!
I must add though, IMHO we should use the term "flip" to describe a rearward tip-over and instead refer to a side-tipover as a roll-over ..... or am I just being a bit too precious? :confused2:
The first thing that occurred to me was this one:
One of the things that gets newby's in trouble is failure to alway keep your Front End Loader as low as possible. I have seen so many youtube vid's of newby's running around with a loaded bucket up high. Absolutely never do that. When you load your FEL bucket lower it as much as possible when you are traveling. I have seen dozens of pictures of rollovers pictures here on TBN, and every one of them had the FEL bucket up high. The tell tale sign of a mistake. Keep the shiny side up, and happy tractoring.
A couple of other points of note (all have been mentioned already - there's a mile of experience on this site:
Filling all tyres with water or specific ballast fluid;
Adding wheel-weights and other low-mounted weight for further ballast and stability;
Keeping tyre pressures correct - nothing worse than an unnoticed soft tyre on a hill-side;
The front axle of your tractor (and most others, including all mine) does nothing to prevent a roll-over;
Appropriate gear, adequate engine speed, sensible approach, correct outcome, and easier on the machine as well.
Slower is safer - it's much better to do a little less in a day, and avoid a visit to the hospital or undertaker, still be able to finish it the next day!
Inattention or distraction can very easily and quickly cause a serious accident;
Above all - with implements (especially heavy ones) and loader buckets (especially full ones): Low and slow, Carefully go.
I've been driving tractors since I was 7 years old ..... sheesh that was a long time ago! :rolleyes:
Feel free to ask about what you need to know - there are a lot of very helpful people here. :thumbsup:
   / Tractor tipping point #29
Ok, just a side note here. The front axle actually DOES have influence on roll over geometrics. It's a common misconception that because the axle has no springs or stoppers on either side of the pivot, that there is no influence on roll over. The axle's pivot location in relation to the rear wheel ground contact and in relation tot he cog play a roll, and a large enough roll that it can be measured, in preventing or causing a roll over to occur. Some axles are pivoted quite high in relation to the wheelbase length and rear track width, others are pivoted lower.
   / Tractor tipping point #30
There are a lot of variables to this. First most likely the tractor will not tip near as easy as you think. Believe most here will tell you they have come out of the seat thinking it was going but it remain upright. Not saying do not be safe, far from it.
You may wish to look at videos on the internet of tractor accidents to get an idea of how far some are pushed before they do roll and they will roll and yes kill.
Some suggestions:
On slopes you are less stable driving sideways, better straight up and down.
Slow is better than fast, a tractor will slower travel over something at high speed that may have bounced crossing and rolled.
Wider wheel spacing is better, check your manual for wheel spacing.
The type of implement you have attached can help make you more stable or less. Wide implements may make you more stable.
Load (even implements) lower are more stable then raised. Of course you must lift them some to transport but if tractor is tipping towards a load, lower it as fast as possible and that may stop the tipping. Say you have heavy load on the rear hitch for front end loader, you drop the load if possible if it tips that direction.
Be sure to keep check on tire air pressure, you do not want a low pressure tire to come off the rim on slope.
Be sure you understand how the brakes work before you get on a slope and you may want to lock so both bake together.
I would suggest you take the tractor only, if it is four wheel drive I would use it and in low gear and slow ground speed with say 15000 rpms so the hydraulics are working pressure and quick response get out there and drive across the different concerns. Begin with one you feel very comfortable with and work up. When you are comfortable at low speed then move up in speed some. Watch you front tires (you will not be able to see rear ones unless in trouble) for lifting off the ground. If that begins to happen-STOP. Land here is mostly level but have had people killed or injured and all the cases I know of were tractors rolling over into ditches (other than accident with auto) or into holes. I really think you will find them much more stable than you think they are. Oh if you have roll bar do wear the seat belt for it should keep you within the roll bar if the tractor rolls. If no roll bar do not wear seat belt. kt
Nice list kthompson. I would add that loads on the rear are more stable than loads on the front because the rear axle is rigid to the tractor whereas most front axles pivot in the middle. When I go on steep sidehills my tractor is much more stable with the loader off and the load on the back tires than the with the loader on because that transfers more weight to the front end.
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
Hidratrak 8' Rolling Cultivator (A53317)
Hidratrak 8'...
2017 Ford Escape AWD SUV (A55758)
2017 Ford Escape...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2007 Yamaha Rhino 660 (A55315)
2007 Yamaha Rhino...
