Do mouse pads wear out?
/ Do mouse pads wear out? #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
I don't know how old ours is but the cordless mouse has to travel 3 times the distance that it used to, just to move the cursor the same distance. I think the batteries are good and I moved the sending unit a little more inline. The mouse is about 3 years old, same as the computer.
/ Do mouse pads wear out? #2
Mice wear out...a couple things...
Mice do not require a pad try some other smooth surfaces...
There are some settings in the control panel to check
Also if the mouse came with a software disk it may have additional drivers that can offer more setting control...most mice will work fine without having to install any additional device drivers
good luck...
/ Do mouse pads wear out? #3
I'm assuming that it's an optical mouse, check and see if there is a bit of lint or desk fuzz up in the tunnel that might be interfering with the beam. Whenever mine acts up that is the cause.
/ Do mouse pads wear out? #4
Yeah, if it's an optical mouse then cleaning the optics with a Q-tip will help a lot. Just did one of mine yesterday and now it works much better.
It doesn't hurt to clean the surface of the mouse pad periodically either. Dust gets into the pad which will cause the mouse to act strangely also.
Excellent!
My first line of defense is usually... ignore it, it'll go away.
So I took your advice and blew into the hole. It worked, so if some is good, more is better, right? I gave it a good shot with the air compressor and it is working like new.
Now my bride is telling me i should have sucked it out because blowing just spreads it around. I'm not sure if i won this round or not.
/ Do mouse pads wear out? #6
Well this thread is gonna show up on a lot of Google searches now.
/ Do mouse pads wear out? #7
Excellent!
So I took your advice and blew into the hole. It worked, so if some is good, more is better, right? I gave it a good ******* with the air compressor and it is working like new.
Um... :thumbsup:
/ Do mouse pads wear out? #8
Note to self:
Don't mention mouse balls. That would be wrong.:stirthepot:
/ Do mouse pads wear out? #9
I have an optical mouse - Logitech. I've cleaned mine by blowing & Q-tip. If yours is anything like mine - blowing will not spread dust, etc inside the unit. BTW - I've learned to hate mouse pads - I'm always running the mouse off the edge of the pad. I just run my mouse on the desk top.
/ Do mouse pads wear out? #11
Excellent!
Your reference to your wife as 'my bride' leads me to believe your life as a married couple is near the beginning...
You will soon learn that she IS ALWAYS RIGHT... trying to prove otherwise will only prove her more right, she wins. It's that simple. Get used to it, go along with it... life is much easier that way... crow can taste great with the proper cooking methods and whatever seasonings she tells you to use! *grin*
As to any other word play and possible innuendo, I'm gonna leave that one go... but maybe she should demonstrate the 'proper way to clean a mouse' just for you, privately. *grin*
Hmm, you've given me an idea....
Oh, and we just calibrated our 32nd anniversary. Time flies when you're having fun.
/ Do mouse pads wear out? #13
Excellent! Congrats on the years together... too many couples loose that 'zest' these days! My hat is off to you both!
/ Do mouse pads wear out? #14
I got tired of having to relocate the mouse constantly when you run out of arm and finally go a "trackball type". All the cursor movement is controlled with the thumb and the mouse remains stationary. I like it but most folks who use the regular mice find it difficult. It does take a bit of getting used to but once you get used to it, you wont go back to a regular mouse. It does require me to pop out the ball occasionally to clean it and the sensors inside.
/ Do mouse pads wear out? #15
Set your mouse pointer speed higher.. I can move all the way up/down, left/right in about 1.75sq inches..
