   / Harbor Freight Tools that don't suck #6,271
   / Harbor Freight Tools that don't suck #6,272
You may want to read the manual for them...
First thing under Operation "Warning"! Never crawl under the vehicle when supporting it with Jack Stands.
I bought my Aluminum Jack Stands back in 2012 I don't know if it still says this or not... I know on all the steel jack stands I have bought from HF it don't give this warning...
Trust them at your own risk. Maybe they have this warning to cover their ***.
So that was your review on HF saying that huh? :)
I have had several stands and some have said not to trust them with your life, some didnt. I suspect the aluminum ones are made by a different OEM than the steel ones and thus the difference in the manual and wording.
........ I don't see your point though as nothing you linked actually talked bad about the HF helmets..
One thing I've noticed is that HF quality is all over the place for the exact same item. Even the reviews HF publishes on their website show a bunch of people that love it and as many that bought a dud. Fortunately, there is often someone who figures out how to "fix" the defect or recognize it before the warranty runs out.
   / Harbor Freight Tools that don't suck #6,274
FWIW my HF Blue Flame helmet works like new in occasional use over 5 years but is too dark for low power welding. I replaced it with one that has ranges lower than its 9 minimum.
   / Harbor Freight Tools that don't suck #6,275
Just announced!! A new HF in Cookeville, TN! This is only about 10 miles from me.
   / Harbor Freight Tools that don't suck #6,276
Interesting. I verify mine a couple of times per project by comparison with two beam torque wrenches, a 1960's Craftsman I bought new and and a Thorsen or something - a US name brand - nearly as old. All three match identical over the 15 years I've had the HF.
I verify mine on a calibration bench. We have to have our torque wrenches calibrated at least annually, for some processes it is more frequent. I do all of mine quarterly, I do not keep them if they deviate more than +/- 1% over a 3 month span.
I only own one beam torque wrench, it is an inch pound, I use it to set preload on some bearing assemblies.
I am just funny that way, I also only use two brands of multimeters and two brands of oscilloscopes, again, just what I have found to serve me in my needs with the highest level of accuracy.
There are other brands with great accuracy I am sure. These happened to have made a LOT of mortgage payments and bought a LOT of food.
   / Harbor Freight Tools that don't suck #6,277
Warning. Don't buy anything the first few trips. Take your wife with you and leave the credit card in your car.
   / Harbor Freight Tools that don't suck #6,278
Thanks, but not an issue - I'm a HF veteran. Many, many $$$ expended there at the Atlanta stores over the years.
   / Harbor Freight Tools that don't suck #6,280
All of these auto helmets use a solar cell and rechargeable LiIon batts.. They do go bad. I dont see your point though as nothing you linked actually talked bad about the HF helmets..
I wasn't talking bad about the HF helmets ... it's all I have. All I was saying is they will eventually crap out and when they do you can either toss them or fix them.
It's been a few years since I fixed one but I just looked back at some links and it looks like they have CR2032 batteries. There are re-chargeable and regular type. I thought I remembered reading somewhere that CR2032's weren't rechargeable but looking again at the links it looks they there is a rechargeable version.
HF Helmet battery replacement webpage?
Reviving an AutoDarkening Welding Helmet
I like them and am glad I didn't spring for one of the more expensive $180+ versions as they appear to eventually die and have the non-replaceable batteries too.
2014 Case IH MD92 Disk Mower (A50515)
2014 Case IH MD92...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
Unused 2025 CFG XZ20R Mini Excavator (A49461)
Unused 2025 CFG...
Sakai TS160 TTS5 Pneumatic Asphalt Roller (A49461)
Sakai TS160 TTS5...
19011 (A48082)
19011 (A48082)
