Glare off hood
/ Glare off hood #1
Blondie70
Poplarville, MS
Kubota L2501DT
Howdy......first post here.
Getting a L3301. Does the hood reflect glare into the eyes when working during a bright, sunny day?
I had to put undercoating on the hood of my other tractor (blue) to kill the glare reflecting off the hood.
I can't stand glare in the eyes and know the undercoating will work beautifully...but this is a bran-new tractor !j
Thanks for any info
Pete:D
/ Glare off hood #2
I never had any issues but you might check with a sign guy that does vinyl wraps. Sure they could do the hood and it could be removed later.
/ Glare off hood #3
Those ''cool'' flat black hoods on old muscle cars and race cars were not for looks.
/ Glare off hood #5
You can use a removable coating as well like plasti dip, a lot of companies are coming out with similar products.
I never had a problem with glare on my B2620
/ Glare off hood #6
A good layer of dirt keeps the sun from fading the paint and reflecting in your eyes.
/ Glare off hood #7
There is paint on a Kubota? I guess after 5500 hours I need to wash mine and see.
/ Glare off hood #8
Ever look at the front end of any aircraft?
They are all painted flat black for that simple reason. NO GLARE!
Even the back sides of propellers are flat black.
On cars and tractors that would not be 'pretty'.
LOL, my tractor is simply dirty sooty black so I have no glare.
Naturally the angle of the hood is a big factor as well, A simple flat hood probably is less reflective than a curved one.
Also the amount of wax U apply is another factor.
/ Glare off hood #10
A nice coating of dust/dirt will cut the glare every time.
/ Glare off hood #11
I don't think I have ever had a glare problem off the hood of any vehicle or tractor but if you do, then let it get a good coating of dust and that will go away. You may have to spray a coating of diesel or other dust attractant on the hood first then find some dry area to dust it up..
I think I only washed my tractors one time each in 5-6 years of ownership, but I do hose off the dust on the cabs windshield now and then and after working in the mud I use a hose to get the mud off but that is all, never any waxing (it is a tractor after all and not a show car).
/ Glare off hood #12
I have the model before yours Blondie and I never had a glare problem when it was new.
/ Glare off hood #13
Scotchbrite.
/ Glare off hood #14
Never had an issue on my L3200. I have had to deploy that large hydraulic sunshade Kubota put up there when mowing west in the evening, but that was a direct problem, not a reflection problem. I usually have dust protection in place too though.
/ Glare off hood #15
Scotchbrite - ha,ha. That a good one - I was thinking steel wool but hesitate to suggest........
Blondie - easy answer, get a pair of sunglasses until the dust builds up on the hood.
/ Glare off hood #16
Wax it heavily but don't buff off the wax. It'll be a dull pasty color but can be removed later if necessary.
/ Glare off hood #17
im the opposite. I wax my hood for a nice shiny glare.
/ Glare off hood #18
A layer of good ole protective dust will stop any chance of glare and also give that brand new paint job some UV protection to protect from fading :cool:
/ Glare off hood #19
Thanks for any info
Pete:D
Instead of under coating, use PlastiDip. It goes on good, but also comes off real easy w/o tearing up the paint come resale time. People do it all the time for cars, 4x4, and wheels..
/ Glare off hood
Thanks for all the comments/suggestions. The plasti-dip sounds like the way to go if I suffer the glare with this new tractor. Will keep in mind for future.
I just got tractor delivered today. Been reading the manual and this thing has a computer. L3301DT.
Hope I have no problems with it. It sure looks nice. Got the loader, bushhog and pallet forks.
Got to get out and see how it runs as my field is about waist high with Bahia grass. This grass will tell the tale as it is the roughest stuff to cut there is (I think) Thanks to all. Pete
Kubota M135GX Tractor (A61166)
Kubota M135GX...
2016 Isuzu NRR 18ft. Flatbed Truck (A61568)
2016 Isuzu NRR...
8086 (A61165)
8086 (A61165)
UNUSED LANDHERO CHAINS & BINDERS (A62131)
UNUSED LANDHERO...
DELTA RADIAL ARM SAW W/ ELECTRIC BRAKE (A62131)
DELTA RADIAL ARM...
Tracks for Takeuchi TB260 Excavator (A61166)
Tracks for...
