The Time has Come. New L3560 Ordered
   / The Time has Come. New L3560 Ordered #31
Awesome machine. That's the same one I'm looking at. I'm looking at getting the 3pt/QA plate so I don't have to change as often. Congrats.
Just an update. I have since added a canopy,loaded the rear tires, installed weld-on bucket hooks, and installed a horn. Another thread has the canopy photos.
With this tractor I find myself trying to find new work just to enjoy driving it. I have no complaints.I have recently found that I need to upgrade to a 6' bushog and that is currently in the works.
View attachment 476548View attachment 476550View attachment 476551
   / The Time has Come. New L3560 Ordered #33
great job on those hooks! :thumbsup:
   / The Time has Come. New L3560 Ordered #34
Yep, hooks look perfect. Hey, don't let a lack of daylight curtail your fun! Some LED work lights are cheap and work great. With a canopy, you should have some perfect mounting locations for lighting in front of and above you.
funny you brought up the work lights. I received the switches for them this morning. Just need to find some inexpensive led work lights. Suggestions?
   / The Time has Come. New L3560 Ordered #36
Man, that is a great looking tractor. Are the new grand L's available without HST or is HST standard? I'm in the small minority who prefer gear drive.
   / The Time has Come. New L3560 Ordered #37
I got 4 x 80w philips from ebay aus$80. Probably cheaper in the states before and after difference pics from the front and one showing the rear lit up
the l60's are available with two other transmission besides HST. FST which is a manual shift with a synchro shuttle for forward/reverse. And a GST which is clutch less shifting with the synchro. Like you I was avid gear. Once i test drove the HST I was all in. Best decision I made.
I ordered some lights similar to those this morning. $19 from Amazon.
Man those things are bright.. I'm so used to the old school halogen work lights.
   / The Time has Come. New L3560 Ordered #40
I cant believe the difference makes a good mobile light rig. I wired the front and back on two circuits when i discovered 20amps dont go through a 10amp fuse
CASE 1150C CRAWLER DOZER (A51242)
CASE 1150C CRAWLER...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A52128)
2020 New Holland...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
Electric Forklift Pallet (A50322)
Electric Forklift...
