Getting a whole house genny installed...
   / Getting a whole house genny installed... #71
Offer is valid only on qualifying purchases between August 1, 2016 and September 16,
2016.
Hmm.. I wonder if the payment isnt made until after 8/1, does that qualify?
   / Getting a whole house genny installed... #72
Nick -
Beautiful documentation on your install.
I would love to have the auto start / automatic transfer switch but for now we make do with a manual transfer switch and running off a Miller Bobcat 250 welder. Keeps the wood stove / well pump / refrigerator and other necessities running when the power is off.
Hope you never need it but who knows with the NC weather.
73
   / Getting a whole house genny installed... #74
Nice installation. Mine is an 11kw Generac and it was installed in June of this year. House is new, with propane fired boiler, cook stove, and clothes dryer; and also a 1/2 hp well pump.More than enough capacity. Nice to have.
How big a propane tank are running off?
   / Getting a whole house genny installed... #77
Nick, I am impressed with your "antenna farm". ( I popped over to your QRZ page for a look) And I am just flat jealous of your whole house generator install.:thumbsup:
Thanks!
Nick
All done. Tech came out today, installed the battery & MobileLink unit, and plugged in the activation code.
Exercise period set for weekly (10A on Saturdays), initial changeover set at 15 seconds rather than the default 5 seconds at my request (we get a fair number of short term dropouts when weather is dicey).
Did a simulated power out (utility breaker on switch turned off), house switched to gen. power in less than 30 seconds. 5 ton heat pump was on a 5 minute lockout at switchover. Lowered the thermostat inside so it would come on for cooling asap & it cranked up as expected as soon as the lockout timed out. (UPS's chirped at heat pump start-up, indicating a momentary voltage dip - but immediately went back to normal wall power). Could not hear any real difference in the engine whether the heat pump was running or not.
Utility power was turned back on at the switch, there was about a 3-5 second delay & the switch relays fired to change back utility power. Generator continued to run a little bit for cool-down then shut off.
There is a 25 hour break in period for the generator, at which point oil & filter get changed. If exercise + outages don't get 25 hours in the first year, a change is done anyway. After that it is done annually or @ 200 hr intervals, whichever comes first.
Nick
   / Getting a whole house genny installed... #80
I had a Generac when we moved in but the idiot who owned the house previously had some idiotic manual start and transfer switch thing going where you had to climb under the house to do the transfer. The circuits he picked to power with the generator were just as idiotic. The auto switch and panel were there but he never had them installed. He had to go out of his way to make it stupid and hard to do.
I got tired of the insanity and relocated both breaker panels to the garage and installed the Generac auto start panel as it should have been. Life is much better now. Of course after I got all of that done the power has only gone out once last winter but it did perform flawlessly. Things are much better now whether or not I'm around.
From some of the crap this guy pulled around this place, it's scarey to think that he used to maintain airliners for a living. It's a wonder it wasn't raining airplanes with him on the job.
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2014 Ford Escape AWD SUV (A55853)
2014 Ford Escape...
2005 Ford Taurus SE Sedan (A55853)
2005 Ford Taurus...
