USED OILS
   / USED OILS #11
Every state and community is different. Texas doesn't allow the sale or use of waste-oil burners/heaters. None of the dumps around here will take it. They won't even take oil filters if they see them. Most oil change service centers and auto parts stores will accept used oil with some volume limits. Best to check around locally. Or return it to the earth and pour it down a gopher hole. :)
I hope you're kidding about pouring in the ground ...:thumbdown:
   / USED OILS #13
Back when I was young and we had more dirt roads than now the state would spray used motor oil diluted with diesel for the dirt roads. That was back in the 60's.
   / USED OILS #14
Yep, and we did oil changes by pulling off in the woods at the farm and popping the plug.
   / USED OILS #15
What do you think people did before Walmart? At one time it was a socially acceptable practice, even encouraged.
   / USED OILS #16
its organic
   / USED OILS #17
It came from the ground in the first place...
   / USED OILS #19
I can only imagine how much water that contaminated the next time it rained.
With so the options that we have available there is simply no excuse for simply dumping oil on the ground anymore. Simply enter your zip to find a locaiton.
Motor Oil Recycling Locations
   / USED OILS #20
Do you realize how many cars and trucks that are on the road that leak oil. I would guess millions . Unless your drinking out of the ditch bank chances of it getting into the water supply are slim. I use old oil for several things including burning brush piles pouring on top of post , treating trailer floors. painting it on equipment for storage . why would I give it away???
UNUSED MOWER KING SSB72 BOX BROOM (A51244)
UNUSED MOWER KING...
2023 Maxx-D TDX Tandem Dual Flatbed Tilt Trailer (A52128)
2023 Maxx-D TDX...
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
110 gal Sprayer Tank (A50514)
110 gal Sprayer...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
