Buying used (250/2500), what to avoid (engine/trans known issues)
   / Buying used (250/2500), what to avoid (engine/trans known issues) #1
davrow
Riverside, CA
Kioti CK27HST
I'm not a truck guy, have never owned one. Now with the tractor and land I feel I need one, but cannot afford new. I'm thinking under 10 grand, probably year 2000-2007.
I need to pull about 9,000 lbs. (total incl trailer) but not often and not far.
1) Would a Ford F150/Dodge-Chevy 1500 do, or do I need to go 250/2500 (brand doesn't matter to me)
2) What should I avoid (I've seen reference to earlier 6.7 diesels having issues)
3) What constitutes too high of mileage (most are around 200,000 at this age/price)
4) At what age/mileage does turbo become a liability
example possibility locally: 2007 FORD F250 XTRA CAB DIESEL RUNS GREAT
Any advice appreciated. Thank you.
   / Buying used (250/2500), what to avoid (engine/trans known issues) #2
I'm not a truck guy, have never owned one. . .
First of all, I would have to have more information to give you any useful advice, but I'll answer your questions in order, with what you gave me.
Will this be a daily driver, or just something to pull the tractor? ("not often and not far.")
1) Could a correctly equipped 1/2 ton do the job? In most cases, yes.
Would it be a good idea? Not in my humble opinion. A 4000# truck pulling a 9,000 load. The tail wags the dog.
The bigger the truck, the bigger the brakes and the heavier the suspension. I would recommend at least a 3/4 ton. (250, 2500)
2) If possible, buy a used truck from someone that you know. Chances are, if they haven't had major issues with the truck in the past 10-17 years, it'll be OK for a couple more. I'm a huge fan of Ford trucks, but not the 6.0 or the 6.4 diesels. (late '03-'10) The '07 in your link will be a 6.0 liter.
Again, you didn't say if this was going to be a daily driver or not. But, if you're not going to be using it much, a gas engine would be fine.
3)Good question. I've seen the Ford 7.3 with more than 500,000 miles and still running strong. More important to me than mileage is maintenance.
4)Really good question. If you get someone to tell you that, ask him to pick you some Lotto numbers. LOL :D
I've seen turbos go a million miles or more (CAT engine in my KW. Changed the turbo at 1,900,000) and I've known of them failing at 1300 miles. (friend of mine's brand new Dodge)
   / Buying used (250/2500), what to avoid (engine/trans known issues) #3
I would definitely go with a 3/4 ton. Even if you don't pull that load that often, when you do you will be thankful and more at ease.
I have been a GMC guy most of the time and would stay away from the 3/4 and 1 ton pre-Duramax trucks. Those diesels seem to be pooches to me and had a hard time pulling 10,000 pounds at highway speed. Just for a few miles would be fine. They still are sturdy enough trucks though.
2000-2002 Duramax's have an issue with injectors so I would be careful with them, although I have one and never had the problem, yet. I have an 02 and can pull a 17,000 trailer like nothing. I never heard of anyone have trouble with turbos as long as after a good pull you give it time to coll, like a few minutes before you shut it down.
   / Buying used (250/2500), what to avoid (engine/trans known issues) #4
Def stay away from 6.0 Fords. You don't need those kinds of problems in your life.
All trucks will have their own issues, but I am a Cummins guy. My 05 has 312K and counting, never an issue with the motor. Been a fantastic truck. It is always either pulling my 40ft toy hauler, or my gooseneck. Ive historically seen better luck with a Cummins by FAR, plenty of friends with 100's and 100's of thousands of trouble free miles.
   / Buying used (250/2500), what to avoid (engine/trans known issues) #5
In my opinion you would be happy with a Chevy 6.0 gas. If your not using it often or pulling really heavy then you would not justify the cost of a diesel. Then you could get a lower mile, and clean truck at a good price and not have much more maintenance than a car. That's my opinion for what it's worth
   / Buying used (250/2500), what to avoid (engine/trans known issues) #6
6.0 Chevy carry about zero value, people give them away. So it's true, you could find a very clean low mileage truck for next to nothing. I'd still prefer diesel, but that's up to you. Better to have more truck than you need, then the other way around.
   / Buying used (250/2500), what to avoid (engine/trans known issues) #7
I'm planning on replacing my farm truck in the next few years. I'll be buying a 2000-2007 Ford f250 or 350 4wd long bed with an extra cab. Definitely a 4wd model, hopefully a v10 gas, but I'd settle for the 5.4 V8. I won't drive the thing very much, but I want something with plenty of power. Purchase price and maintenance will be a lot less than a diesel. Just my personal thoughts on the matter.
   / Buying used (250/2500), what to avoid (engine/trans known issues) #8
Manual trans in a gasser superduty will do well for you. Auto trans issues in the diesel versions from 1999 to 2003, same trans in gassers. V10 if you don't care about fuel mileage and want nearly the same power as a diesel.
   / Buying used (250/2500), what to avoid (engine/trans known issues) #9
Thats funny about giving the 6.0 chevy gassers away,not around here they don,t.Nice truck IMHO and thats coming from a ford,dodge person.OP,I would try to find a good used 3/4 ton in a gasser model..
   / Buying used (250/2500), what to avoid (engine/trans known issues) #10
They don't give them away around here either. I prefer Ford trucks too but I sold my F350 4x4 dually crew couple years ago because we quit camping and bought an 07 Chevy 2500 HD 4x4. It has the 6.0 gasser and does fine pulling a 14' covered trailer and a 20' equipment trailer. Not easy on gas though with 4.10's. Other than that I really like the truck. Friend of mine that is in the landscaping and mowing business just traded his 06 F350 in on a new Dodge due to issues with the engine. I owned the last of the 7.3's in my 03 and it was a great engine. If you are set on a Ford diesel get a 6.4 or a 6.7. It will be difficult to stay under your 10K budget. Duramaxes have their issues too with the LLY models and overheating. Diesels do out pull and out perform gassers but for now and my occasional pulling needs a gasser is OK.
UNUSED INDUSTRIAS AMERICA 190 HYD SCRAPE BLADE (A50459)
UNUSED INDUSTRIAS...
UNUSED KJ HOT-DIP GALVANIZED WELDED WIRE MESH (A50460)
UNUSED KJ HOT-DIP...
Year: 2022 Make: Kawasaki Model: Z125 PRO Vehicle Type: Motorcycle Mileage: Plate: Body Type: Trim (A48082)
Year: 2022 Make...
(1) 10ft Tarter Gate (A48837)
(1) 10ft Tarter...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A48837)
New/Unused 7ft 20...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A50397)
80in HD Tooth...
