Midniteoyl
Super Member
- Joined
- May 20, 2013
- Messages
- 5,072
- Location
- N. W. Indiana
- Tractor
- Kioti CK3510SE HST, Ford 3400, Gizmow ZTR, Simplicity 7016H
So, I found -20 WWF for $1.50gal and bought 124gal to refill my tires. This saved me anywhere from $100 to $225 over buying it in 55gal drums. However, I now realize that I have no idea on how to get the WWF into the tires
I need to get fluid back in as I recently found that they were filled with plain water, then one was drained, and the other was partially drained (or never fully filled) prior to my owning it, leading to rusting of the rims. As I dont have the ~$1000 to purchase tires and rims at the moment, I figure refilling will hold off further rusting until I can.
So, anyone have a good, cheap, way to fill the tires through the valve stem from gallon jugs? Can I use a cheap 12v transfer pump such as this one? Amazon.com: ABN 12 Volt Oil Fluid Diesel Extraction Pump 8 Amp 1 Watt: Automotive or even Amazon.com: Amarine-made 12v Diesel Biodiesel Kerosene Pumpcast Fuel Oil Transfer Pump 175w 11gpm: Automotive ?
Any ideas or comments appreciated..
