C4Ranch
Fantastic work! I'm impressed! Did you consider an electric tankless water heater? Seems it would be more efficient than a heat pump heating a tank of water but I don't know anything about the unit you have admittedly.
Awesome setup. I designed my own with a little help from Norther Arizona Wind and Sun after being told there was no way I could do it by myself by the "professionals". They were wrong, all of it is basically plug and play once you figure out the basics. My little system pales in comparison, just 3.3kW but is enough for the small cabin it is in, it even powers the 48 volt mini split heat pump.
Yes they are, the company is great to deal with too, if you are talking about Hotdpot Energy. I only had one installer offer to help, he sent me the entire solar certification course in .pdf because he was too busy to even come give a quote.
One member here was a huge help with fine tuning and protecting the system, TnAndy.
NAWS is also great, they checked over my plan, suggested a better solar panel and j bought it all from them except the batteries, which I got locally. I am only running 16-305ah 6 volt batteries but it has been more than enough. Off grid Outback system with grid backup. We have electricity but the cabin/guest house was designed to be self sufficient. On demand hot water and LP stove with led lighting. I wanted to do the main house as well but won't because our electricity is cheap and reliable. That and the construction is killing the budget. We went from 2000 sq ft to over 3500 with no regrets.
Running a little over a year in Bertram Tx, roof mounted and we are living in this little 24x24 place with 14' walls and a 12x24 loft while I build the main house, mostly by myself. How soon do you hope to have the rest of the system finished?
I am jealous because you are doing what we had originally wanted but if we ever do it, it will be a retrofit but the house is set up so it can be added easily.
When building this all myself, the most difficult part is managing time between working outside on the land, finishing the inside of the house or working on the power and water systems.
I'll have the majority of the power system done this year, with inevitable upgrades (why I went with a modular system).
The finishing on the house is happening quickly (as quickly as I can), I am focusing on mud and tape, priming and painting this next week and then flooring. Matter of fact, the house got its first fully functional shower this afternoon.
A lot of people misunderstand. It takes a lot to mold raw land into a water and power bearing monster and construct a home on it by yourself. Most people ask "is your house done?" ... I don't even know how to answer, because it isn't something that I can say is 'finished'.
~Moses
~Moses
This is my exact world! The best part for me is when people realize that I am basically doing everything by myself, and we started its unimproved land. It opens their eyes and so far the response has been amazing. I am at walls and in a few weeks there will be A/C then I can work past noon each day. I am too old to work in 100 degree heat so I work like a maniac until it gets too hot.
One nice thing about this forum, there are many who do it and understand completely.
6 tons of Mitsubishi mini splits, I hate ducts.
Yeah but your weather is better, cooler nights. I was almost convinced to go with the Chiltrix chiller mini splits, but the Mitsubishi's were cheaper installed than I could buy the components for with the chillers, then I would have had to install them. My goal is to be living in the main house by Christmas and it will be pushing it as it is.
The 6 tons is slightly overkill according to the manual j report but with mini splits it is not bad to have more than needed.
Moses I hope you keep this updated with your progress, it will help those of us who want to do the same thing.
