   / Harbor Freight Tools that don't suck #6,191
That reminds me - I have a "Pittsburgh" (HF) 15" adjustable wrench in the tractor "toolbox" dedicated for adjusting the top link. 15" Jumbo Adjustable Wrench
Due to the poor conditions, it is all rusty and terrible looking, but works great! I give the adjustment nut and sliding jaw a shot of Fluid Film occasionally to keep it limber.
I've got one similar to this 24" adjustable wrench for big bolts.
24 in. Adjustable Jumbo Wrench
Tight hitch ball? No problem and with a recent sale price of $19 and a 20% off coupon it's a steal at $15 and change. USA made would cost a king's ransom and only get used a few times over it's life. This is cheaper and works almost as well.
   / Harbor Freight Tools that don't suck #6,192
Anyone use one of the OBD II scanners? I need to look at a code in WRX and clear it now and then, until it gets tuned.
   / Harbor Freight Tools that don't suck #6,193
Dont know if they cover Subaru but I dont know why they wouldnt: Amazon.com: KONNWEI KW902 Mini Bluetooth Wireless OBD-II Car Auto Diagnostic Scan Tools(Black): Automotive
I bought one and it works on Android and WinPhone.. You can search for ones that work on Apple if you have an iPhone. I simply keep it plugged in all the time and turn it on when needed. Software to look at all the stats and info, read and clear codes, real time engine information (load, MPG, O2 sensors, RPMs, Fuel Trim, etc), dashboard, etc are available in the appropriate app stores.
   / Harbor Freight Tools that don't suck #6,194
Wheel bearing puller and installer.
FWD Front Wheel Bearing Adapters
Pulled and installed one bearing with no problem. Stripped the bolt thread and deformed the nut threads on the second pull.
I replaced the all-threaded 7 inch, 3/4 x 16 bolt with 6 and 7 inch grade 8 bolts, not all-threaded, and a coupling nut, then finished the job. I also bought a 6 inch all-threaded grade five 3/4 x 10 bolt (longest they had). I used it after breaking the bearing loose and for pressing in the new bearing so I wouldn't have to change bolts.
Bruce
   / Harbor Freight Tools that don't suck #6,195
   / Harbor Freight Tools that don't suck #6,199
My initial thought was 'yikes' but the reviews sure seem solid.
Exactly my thoughts after reading the reviews, It's very much like Woodland Mills sawmill. I wouldn't be surprised if they are made side by side in the same chinese factory.
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2014 Gillig 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig 31+56...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2018 CATERPILLAR 336FL EXCAVATOR (A51242)
2018 CATERPILLAR...
CATERPILLAR 12" BACKHOE BUCKET (A51242)
CATERPILLAR 12"...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
