FYI: Fuel usage with a 3520 and a MX5
   / FYI: Fuel usage with a 3520 and a MX5 #11
Just finished mowing 45 acres with a 3520 and rc2072 6 foot. 31 gallons, 24.5 hours on the meter, 27 rocks to trim around, 2.5 miles of edge trimming, mostly thin grassand small bushes, 2 acres of heavy 3 foot grass. Full throttle 2800 rpm.
   / FYI: Fuel usage with a 3520 and a MX5 #12
1-1/4 gal per hour certainly aint bad. My L3400 was a tad less HP and a bit lighter too to get ~1 gph.
How often you do those 45 acres? Never done anything that big. Biggest I did was ~20 acres with my L3400 / 6' cutter. Never anything that took more than a day to do.
Did 30 acres +/- with the mx5100 in ~8 hours. I would have had to really push it to do 45 acres in a day. Have you considered larger equip?
   / FYI: Fuel usage with a 3520 and a MX5 #13
I mow once a year in mid July. Its a 270 mile one way tow with the f150 / 10k trailer which limits size, could probably go up 1 frame size and be a little faster/ less bouncy on the mow. 3520 is really bouncy compared to a normal farm tractor��
   / FYI: Fuel usage with a 3520 and a MX5 #14
Same fuel economy I got with my old L3400 bota, be it with a 5' or 6' cutter.
My new MX5100 with 8' cutter is ~2 gph. But I can cut about twice as fast also:thumbsup:
About the same for my MX5100, maybe a little less.
Any pics of that MX5100 posted?
   / FYI: Fuel usage with a 3520 and a MX5 #15
Thanks all for the additional fuel usage data!
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2025 JMR 40in Single Cylinder Brush Grapple Mini Skid Steer Attachment (A56857)
2025 JMR 40in...
2020 PRAT TL (A55758)
Portable Restroom (A54865)
Portable Restroom...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
2022 Diamond T 14' Dump Trailer, VIN: 5FWDS1423NR030358, Tandem Axle, 7 Gage Steel Floor, Power (A59076)
2022 Diamond T 14'...
