Post hole digger for a 1720D?
/ Post hole digger for a 1720D? #1
1720DnTennessee
Tennessee
1720D
I am thinking about getting a post hole digger for my 1720D but was wondering if the tractor is large enough to handle one?
/ Post hole digger for a 1720D? #2
yep sure is. They do not take much power to operate one. After all think of those little two stoke augers you see folks use. those are basically weedeater engines. Granted the auger is not as big but you have way more torque and power than those have.
I have used one on my ym2000 and it would go all day long at barely above idle. The only thing is they don't like hard ground but a 50hp tractor would have the same problem there.
/ Post hole digger for a 1720D? #3
Been using one for the last few years on my 1720d. 6" auger for fence posts and a 12" for tree planting.
Works fine.
That makes sense. Thanks.
/ Post hole digger for a 1720D? #6
I drilled about 200 holes w/my 1610d...russ
/ Post hole digger for a 1720D? #8
I punched quite few holes with a 9" and 12" auger behind my YM1700. The trick is nice and slow. And raise the auger quite often to clear the dirt off.
/ Post hole digger for a 1720D? #9
I have a 6,9 and 12" auger and my 1500 drives them easily even in hard ground. Sometimes I even have to get off and jump on the hitch to help it dig....
/ Post hole digger for a 1720D? #10
Hey, There are a few of us here in Nashville with Yanmars. We tend to share a International Group Cat-1 auger with a 9-in hole cut. YM2610, YM1720D and a YM1700D.
I must say, I would prefer the 6-in hold cut for wooden fence posts. Less sloppy in the hole. ALSO, if you snag a tree root or hit rock gravel (often in TN), I strongly advise having front weights to counter balance the sudden jerk. Without them, an auger will catch a root, spin suddenly into a death spiral and nearly flip the tractor pointing straight up.
If you ever get the auger stuck in a hole, disconnect the PTO drive shaft and slowly back the PTO shaft in reverse manually. If it's rock hard stuck, doesn't budge, using a standard green T-post in the PTO U-joint closest to the head will work too. Just make sure the sheer-pin is just that a real sheer-pin, not some harden bolt. This way, no harm to the PTO U-joint sticking the T-post into it to leverage with. Lastly a shovel and hours is the other way.
/ Post hole digger for a 1720D? #11
The best match to a digger would be the one designed for compact tractors. It has a shorter boom and shorter auger. Sometimes the longer standard auger has trouble clearing the hole because not enough travel on the tractor 2 point lift. Ken Sweet
/ Post hole digger for a 1720D? #12
I would agree. A CUT Cat-1 should have plenty of lift for a normal auger. Mostly the Yanmars around the 2000 and higher in numbers. The SCUT Cat-1 being closer to the ground and the lift arms shorter have a short travel distance, thus a small boom and less height auger would be ideal. On the bottom end of the SCUT tractors, the lift is CAT-0. Not sure if any augers exist for that.
2013 KENWORTH T6 SERIES (INOPERABLE) (A65643)
2013 KENWORTH T6...
2018 Jeep Grand Cherokee Trackhawk 4x4 SUV (A64557)
2018 Jeep Grand...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
Butler MFG Water Tanker (A63689)
Butler MFG Water...
1947 Chevrolet Panel (A62613)
1947 Chevrolet...
New/Unused Landhonor 16ft x 13ft Metal Carport (A65583)
New/Unused...
