How would you compare two HST transmissions?
/ How would you compare two HST transmissions? #21
The only reason that is needed is because the engine isn't torquey (is that a word?) enough to push into the pile in high range. One way to skin that cat would be to give it a low gear to compensate, and if you go that route, then indeed being able to shift ranges in the fly is a plus. My analogy to the Mack was to point out another approach. Instead of needing a 3 speed transaxle like the freighliner, Mack built an engine that had such torque rise that it kept pulling down at 800 rpm. If your tractor could push in the pile in high, you wouldn't care if it was easy to shift into low.
There are surely downsides to that approach, but from an operator's standpoint having to shift bless often is better in my opinion.
/ How would you compare two HST transmissions? #22
Yes the tractors are unable to push into a pile of dirt in high and sometimes medium. I can also drive on the road in HH and shift into HL to pull a hill.
/ How would you compare two HST transmissions? #23
I can drive into a pile in medium, just the same as my buddies L5240 ... I only have 3 ranges, he has 6. Our torque numbers are nearly identical (mine has a bigger engine but he has a turbo). Maybe my 3 range HST is stronger than Kubota 6 spd (LOL jk)
/ How would you compare two HST transmissions? #24
My Kioti just has a regular old garden variety 3-range HST. I would pay more for HST+, but I wouldn't exclude all other brands from consideration because of it.
It would certainly be a factor in the decision, but there are other things that I consider to be important on a tractor than the HST+ transmission.
/ How would you compare two HST transmissions? #25
I have the 3 range ehydro in my 4520 which works well but would prefer the high/low option the HST+ has. That is a feature the Kubota has that is an improvement over Deere and other brands imo.
Pulling a box blade in L then being able to back up in H would a time saver for me. When you consider that the range gears on a hydro set up are not synchronized, then shifting all day long can be irritating.
I have not read any complaints from owners of the HST+ transmissions either. To Kubota's credit it is a good design and works very well.
/ How would you compare two HST transmissions? #26
In all fairness, HST+ isn't the only reason I'm mostly only looking at Kubota to replace my Kubota L3200 with a premium cabbed machine.
I'll probably be looking at Kioti again as the Kubota's I'm now looking at match up size wise with their smallest premium cabbed machines. Kubota quality & HST+ will be hard to beat though.
It's annoying to have to shift between L & M when digging stuff out of a pile, then transporting it a ways. My L3200 doesn't have the torque to pull it off in M regularly, especially if the pile has settled a bit. The L3800 which is the same machine with 6 more HP might, but I duno. If we had unlimited torque, we'd need no gears at all.
/ How would you compare two HST transmissions? #27
Hook 'em draw bar to draw bar and see what will pull more.
/ How would you compare two HST transmissions? #28
Well, that's interesting. The HSTs can't spin the wheels in M range. I don't feel so bad about having an old gear tractor now. :laughing:
/ How would you compare two HST transmissions? #29
That would be interesting... I think we will
/ How would you compare two HST transmissions? #30
Mine will. Sure won't spin them in Hi though.
/ How would you compare two HST transmissions? #31
/ How would you compare two HST transmissions? #32
You will drag him if he is in Medium high but idk about medium low.
How fast will your tractor run in low and medium range?
/ How would you compare two HST transmissions? #33
Hmm... I think in low right around 4 mph, in med around 8... Hi around 16
/ How would you compare two HST transmissions? #34
If you were comparing two tractors, all other specs/features being mostly equal how would you compare the transmissions or otherwise pick a winner?
I would see how they were geared,check how well the hydro stopped each one, and I would stomp down on the hydro pedal to and do some quick forward to reverse to see how responsive it was.
/ How would you compare two HST transmissions? #35
That sounds right. Usually medium is half of high and low is half of medium.
Low for me is 5. something. Medium is 10, and high is 21.
/ How would you compare two HST transmissions? #36
With a light amount of ballast I can. With the loader, loaded tires, and backhoe attached I can't. With the loader and loaded tires I can.
/ How would you compare two HST transmissions? #37
Tire size plays a role also... My previous 1648 (lower HP) had 14.9x24 rear R4's but my 1652 has 17.5Lx24 rear R4's... The 17.5Lx24 are wider, but the 14.9x24 are a tad taller. Consequently, the 1648 traveled slightly faster than the 1652 does.
My buddies L5240 has identical tires to mine, so that would help the test stay fairly equal.
/ How would you compare two HST transmissions? #38
Why would you want too?
If you can't spin the wheels then, you can't pull to its full potential. Maximum pulling power is reached right before the wheels slip. If you can't spin then you never reached that point.
/ How would you compare two HST transmissions? #39
The tread design is important too. I see some of these CUTs with horrible looking R4's. I my 4240 had more agressive R4's on the rear.
/ How would you compare two HST transmissions? #40
Here's mine. I have seen some that looked more like turf tires. They are nearly as aggressive as ags, but they are much wider. I like the width, it doesn't cause ruts as bad as a narrower tire. image-542677385.jpg
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A61572)
2023 New Holland...
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
CLARK WAREHOUSE FORKLIFT (A63291)
CLARK WAREHOUSE...
PALLET OF MISC WIRE, CHAIN, ELEC. MOTOR (A63291)
PALLET OF MISC...
2014 Ford Escape SUV (A61574)
2014 Ford Escape...
