Tool box on new 2538?
   / Tool box on new 2538? #1
screamin400
Lee Center NY
2016 Mahindra 2538, 2016 Mahindra 2655, 2017 CaseIH 75C, 2021 CaseIH 110c., 2020 Kubota svl 65-2, 2022 Kubota svl 75-2, Kubota svl75-3, Kubota M6
Looking to see if any of you folks have a good idea for a tool box for my new 2538? It would be nice to be able to have a couple of straps with the tractor at all times. Then I need to look into the cup holder :)
   / Tool box on new 2538? #2
I attached a small tool box to the ROPS using a square U-bolt from tractor supply
That right there may be so simple that I never thought of it. I take it that you have no issues with it being in the way of anything?
   / Tool box on new 2538? #4
It's a small box mounted on the right side so it's out of the way. I was considering to an ammo can painted to match tractor but went with the plastic box because it held all the items i needed. It doesn't interfere with using backhoe. By using the clamp I avoided drilling holes in the ROPS.
Appears it is mounted above the rops pivot point?
   / Tool box on new 2538? #6
It's mounted below the pivot point
   / Tool box on new 2538? #7
got room behind the seat for a couple ammo cans?
Picked up a small steel tool box at runnings today for I think it was 17 bucks. Bolted it to the two fender mounts and let it rest on the plastic of the fender. Have to see how it works out.IMG_5693.JPG
28013 (A50322)
28013 (A50322)
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
2020 FABRIQUE H9618TRTV-100 18FT ENCLOSED TRAILER (A51222)
2020 FABRIQUE...
Kinze 840 Grain Cart (A50514)
Kinze 840 Grain...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
Bobcat Skid Steer Forks (A50322)
Bobcat Skid Steer...
