Ford 771 front loader can not pick the front wheels of a 1974 ford 3000.
   / Ford 771 front loader can not pick the front wheels of a 1974 ford 3000. #1
Blasterfool8
St. Louis, MO
1974 Ford 3000 w/ a ford 771 loader
Hi, my name is Ben, im 21. I recenty purchased a 1974 ford 3000 gas with 8speed transmission. It came with the orginal manuals, a ford 771 front loader, bale spearand front bumper for 4500 everything works fine, other than needing to replace the dual servo brake shoes and brake drum. I replaved 3 hydralic 3/8 hoses on the front of the loaders on the bucket hydralic. But the loader does not seem to be powerful enough to pick up the front
wheels off the ground. Everything works but when i lower the bucket it seems to fall like theres is not any resistance to slow it down. Idont know if thats normal. Can you give me any ideas?
Also is this loader too small for the size of this tractor? I know its one of the 3 loaders that that is the smallest from the other two models 772 and 730. Im going to be using the loader alot.
   / Ford 771 front loader can not pick the front wheels of a 1974 ford 3000. #3
I'd start by measuring the hydraulic pressure the pump can produce, both at idle and higher rpm. Then you'll know what you have to work with. I'm not familiar with your particular tractor, sorry.
   / Ford 771 front loader can not pick the front wheels of a 1974 ford 3000. #4
I forgot to respond yesterday. You say it falls like there's no resistance and won't pick up the front wheels. This sounds like it's in float position. If the bucket is on the ground and you roll the bucket to dump, does it lift the tractor or lift the boom arms of the loader or nothing? If you have an accessory valve with float, they usually go into float when pushing past the normal down position on the valve. Are there upper and lower hoses going to the lift cylinders?
   / Ford 771 front loader can not pick the front wheels of a 1974 ford 3000. #5
Check your hyd valve, it may have the bucket set da, and the boom, sa.
Also check the lift cyls, are the boom cyls sa?
Yes, the first thing i tried was rolling bucket on the ground and using it to lift the bucket to dump, and yes it does lift the boom arms which i thought wasn't supposed to be like that from my automotive care. where is this accessory valve usually located? I just brought a 5000 psi gauge need to set it up.. I just brought materials to build a rops so ive been busy and my summer classes are coming to the end. I also discovered that when i put the lift Cylinders up one side shot up fluid so i ordered both sides seal kits. To your question about the lift cylinders there is only a upper hose which makes me believe it can only go up unlike my bucket cylinders with two, unless the lift cylinder is a special type that i dont know of
Im going outside to get some pictures.
Well here are some photos of the hydraulics 20160714_215141.jpg20160714_215123.jpg20160714_215112.jpg20160714_215019.jpg
Im think the lift cylinders are only single not double... :banghead: If the lift cylinder are are only single are u still able to use the bucket it pick up the tractor?...
   / Ford 771 front loader can not pick the front wheels of a 1974 ford 3000. #10
Nope.. You will need da boom cyls, and a valve capable of it, which yours MAY be, might just have that spool in sa mode.
2021 Takeuchi TL12V2 Skid Steer (A51242)
2021 Takeuchi...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2013 PETERBILT 367 (A50854)
2013 PETERBILT 367...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
1993 Ford Ranger STX Ext. Cab Pickup Truck (A50323)
1993 Ford Ranger...
1995 KOMATSU WA320-1 WHEEL LOADER (A51242)
1995 KOMATSU...
