What is this light?
/ What is this light? #1
salsaboy
Middlesex, NC
Window Shopping/Wishful Thinking
Looks like an acorn.
/ What is this light? #2
I have not found it in either the Mahindra or TYM manual..... but, I would bet that it is water in the fuel filter... Just from the picture. You should never have that come on unless you are not practicing safe ***, I mean putting only fresh clean fuel in your tractor. I have been driving diesels for over 20 years and never have had a water problem.... But I am allergic to penicillin from too many trips to Manila and Saigon... [[ :) ]]
/ What is this light? #3
Yup, that is a ' universal symbol ' for water in fuel. It shows a filter with a water drop underneath it.....
/ What is this light? #4
Back off the water drain from the filter until it lets it out.. do that for a bit until you smell good fresh fuel. Also would unplug the sensor at the but connection to the harness and be sure theres no build up inside
I'll check it tomorrow. The manual is sparse on information.
/ What is this light? #7
Meh.... that's what us dealers are here for
No, that is not the way to look at it. Mahindra needs to get to work and produce some decent manuals. What they put out now is pitifully inadequate. It's not like there is any significant cost involved in doing the job right. Plus they are doing nothing to compensate for their crappy manuals. At the very least they could put the info on their website and make it available until they can get some decent documentation done.
/ What is this light? #8
The info should be there that im not arguing or trying to defend them on that side of things... they have needed updates in manuals and customer info for a while... im just telling you how to fix it now.... that's why we are here.. im not going to charge anyone or tell them they should bring it in when I can help them over the phone.. if you really need info that bad you gona figure out how to get it or stomp your feet and throw a hissy while you waste more time
/ What is this light? #10
Funny I've been both places and Bangkok too and never needed any shots, not that they didn't try but the test was always negative. It must be either good luck or good shopping skills. Never go shopping with your beer goggles on.
:) :) :) Any port in a storm....... at least I never got any tatoo's with my beer goggles on....
/ What is this light? #11
Nether did I. Fashionable or not, I still won't get one. I think they look dumber than ****, especially on women. About as classy and tasteful as graffiti.
I removed 10mm plug at the top of the fuel filter housing and gave a few pumps of the primer on top. Fuel came out and it looked fine. Shouldn't there be something at the bottom of the filter since water is heaver than fuel? I unplugged the sensor but didn't see an obvious way to get the sensor off the bottom of the fuel filter.
/ What is this light? #13
The water sensor on the bottom of the filter is also the drain.......... unplug the sensor then unscrew it until fuel starts coming out
Thanks Navasot. That was exactly what it was. The sensor on the bottom looks nothing like it should turn and any twisting action would cause it to break right off.
I'm running the red dyed farm diesel so it was really easy to see the clear water change to the red diesel.
/ What is this light? #16
I don't know about your model but on my 1538 there are two fuel filters. The prefilter has a replaceable paper element and it is the low point in the fuel system. The final twist on filter is where the moisture sensor is and it's much higher up in the fuel line so if you have water there, then the lower pre filter is likely full of water. The prefilter does have a 10mm drain plug just off center on the bottom of the canister. However if I ever found water in it, I'd replace the paper element so it didn't turn into paper mache and clog up my fuel system.
/ What is this light? #17
the upper filter is were the water is caught and drained which in return cuts the light off .... but very valid point since there was indeed water running through it... think its $11 filter anyway
Looks like I only have the 1 spin on bosch filter.
/ What is this light? #19
Right but you have a canister element filter in the system as well. you have to take the bolt off and slide the can down then pull the filter out of the can.
/ What is this light? #20
Yeah the bottom element is a cheap paper affair. It looks like someone rolled up some scrap cardboard. My guess is that if the upper filter had any water in it the bottom element is saturated and ruined. I think they should put a regular sediment bowl and drain down there at the low point where you could see and drain water before it makes it's way any further in the fuel system. The so called moisture sensor is placed where it reports problems after the fact. It needs to be moved to the lower filter where it would do more good. The sensor is just two pins spaced about 0.10" apart so it's nothing exotic.
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
Pallet of Fork and Frame Mini Skid Steer Attachment (A61567)
Pallet of Fork and...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
2005 Ford F-450 Dump Truck, VIN # 1FDXF46P65EB16866 (A61165)
2005 Ford F-450...
2005 Ford F-250 Utility Truck, VIN # 1FDSF20P95EA36128 (A61165)
2005 Ford F-250...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
