tbzep
- Joined
- Jul 4, 2008
- Messages
- 92
- Location
- TN
- Tractor
- 1948 Farmall Cub, 1952 Ford 8N, 1962 Ford 861 (sold), 2015 Mahindra 3550, 2017 Gravely ZT HD 52
I completed all of the 50 hour service today except the hydraulic portion. The manual just says to check the transmission/hydraulic fluid, but from looking underneath today it looks like I will have to drain it in order to clean the strainer and replace the filter. I don't have 10 gallons of fluid and I'm not even sure what kind to use yet as I've lamented in another thread, so that will have to wait a few days.
Some notes:
It takes a long time for the 3550 to warm up the oil. I ran it for a good 15 minutes and it didn't seem any warmer than the 95 degree shop air.
The drain plugs are 22mm if anyone wants to know what to grab before getting under the tractor.
The oil comes out fast. If you use a specialized oil catch pan, make sure it has a large air vent so it won't overflow.
I had to use a breaker bar to get the drain plugs out. Even factoring in paint adhesion, they had to be way over the 22-29 lb/ft in the manual.
The spin on filter was tight enough to cause me to bend my filter wrench.
The drain plug magnets caught a heck of a lot of crap. Including a couple big chunks of blue silicone held down by bits of metal.
The thresh guard is a nice idea, but poor execution. You have to take off the side panel or the top bracket to remove it.
Battery connections weren't seated well on the posts from the factory.
Hoses and cables hang all underneath the tractor. I have a bad feeling I will eventually hang one or ten of them. That's pretty shoddy design work, IMHO. Unfortunately, that's also the way some other brands looked when I was shopping for a tractor.
And last, but definitely the most annoying. The manual says the dealer has to reset the service reminder indicator. :mur:
Drain plugs...glad I did it at 50 hours.
After a few swipes with a rag...
Some notes:
