Any J Series Owners Tried a Quick Hitch?
   / Any J Series Owners Tried a Quick Hitch? #11
Correct, all QHes are designed for Cat 3 pins. I have a couple implements (rototiller & ancient flail mower at least) I haven't bothered putting bushings on yet & they work just fine without. I'm sure the pins are wearing faster, but noting noticeable.
The QH puts the impliments a few inches further back. It can cause PTO shafts to be to short & decreases lift capacity. Not a big issue on my 3,500lbs (loaded) 32hp L3200, but probably an issue on a smaller machine.
   / Any J Series Owners Tried a Quick Hitch? #12
I recently put Pat's Quick Hitch on the LS. It is easier to adapt to the variety of old 3pt implements that I have. What I don't know yet is if the extended arms will get in the way of remounting the backhoe.
DaveNJ - Did you ever get an opportunity to try remounting your BH with Pat's Quick Hitch installed? I have an XJ2025H TLB due to be delivered soon and am considering buying Pat's Quick Hitch system as long as it doesn't interfere with the BH.
   / Any J Series Owners Tried a Quick Hitch? #13
Really? You spent an extra $75 so you wouldn't have to spend $5 on bushings? :confused3: I guess everybody needs to justify something. I don't use any bushings on my implements. And I don't have to get off the tractor to connect the top link. That's worth more to me than five bucks.
   / Any J Series Owners Tried a Quick Hitch? #14
Haven't used the backhoe in a while but I need to install 300' of electrical conduit before the end of the month so I will let you know. FYI, once you get used to it the BH comes off and on fairly easily.. The first time maybe a little tough. Also, on mine, the hydraulic hoses disconnect in a way that they were too short to reconnect the loop when the BH was removed. My dealer spoke with LS and gave me a hydraulic hose connection to complete the loop at no charge, I think if the factory installers make the hose disconnect at a different location you have enough hose to make the loop with the backhoe off.
   / Any J Series Owners Tried a Quick Hitch? #15
2008 Ford F-450 (A53314)
2008 Ford F-450...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
Set 4- 10-16.5 tires/wheel for bobcat (A55787)
Set 4- 10-16.5...
2024 AGT LRT23 Mini Stand-on Track Loader Skid Steer (A53421)
2024 AGT LRT23...
Yamaha (A55758)
Yamaha (A55758)
2012 Cadillac CTS Sedan (A55758)
2012 Cadillac CTS...
