318 no start
/ 318 no start #1
weeder
Tuscola Illinois
John Deere 425 lawn tractor
HI everyone, a friend of mine stopped by the other day and wanted me to post this on here. He has a 1986 318 and it has sat for about a year. He wants to try and get it going but when he turns the key all it does it clicks. He has replaced the following.
1. PTO Switch
2. Neutral Safety switch
3. Light switch
4. Battery
Here are the #'s he gave me
1.John Deere 318 1986
2.#MOO318X368729
3.Motor-ONAN B43G
4.Motor serial # 863 96 4535
Well I hope this helps a little maybe you guys on here can help the guy I am going to try and get down there when I get a chance and help him too.
Well Thanks
weeder
/ 318 no start #2
Starter or starter celenoid if it has one external to the starter. take the starter to NAPA have them test it. Takes 5 minutes to take that off.
/ 318 no start #4
could try jumping right to the starter to rule out it,
sometimes key switches carry current for the charging circuit and can go bad causing
voltage issues.
/ 318 no start
voltage issues.
Is the starter easy to get to on a 318? Is there a way to jump the starter and not burn anything up?
/ 318 no start
I heard that on a 318 you have to pull the engine to get to the starter? Is that true???
/ 318 no start #7
I had a 318 with an Onan years ago. I cannot remember but I would be surprised if you had to pull the engine. But try the other things mentioned above by other posters first. Tight connections clean battery connections. Try jump starting it just in case battery is dead.
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
New Holland TC35D Tractor w/ Loader (A64047)
New Holland TC35D...
POWER TECH GENERATOR (A63569)
POWER TECH...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
Bobcat T76 Compact Track Loader (A64047)
Bobcat T76 Compact...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
