JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 4,136
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
This is a 1232 Gravely rear-engine rider. I was guilty of cutting too tall wet grass too long and burned off the belt. Not the first time. Happened 4 years ago too. Working fine right to the point of the belt demise. Shut it off, replaced belt. NOW the engine starts fine with the brake depressed and the seat switch defeated. Normal. However, releasing the brake kills the engine. So does trying to engage the blade clutch. I can find no damage or loose wires from the belt debris flying around under there. Trying to move the machine using the hydrostatic pedal of course kills it because the brake is set.
So I'm hung. Can't release the brake nor run the deck. It is not the seat switch (because it is bypassed but also because the engine starts OK proving the bypass works.)
Am studying the wiring diagram and there are enough non-standard symbols and mysteries that I can't see how one bypasses all the safety crap long enough to get it usable or to sort out what the problem is.
Anyone see this before ? Ideas ?
