How to brushhog uneven terrain without damaging equipment
   / How to brushhog uneven terrain without damaging equipment #1
nschneid
Blanchard, OK
Kubota L4400
To preface, I've already bent the mower deck on my Cimmaron 6' brushhog. They fixed it at the shop, somehow, but in doing so they ground off a bunch of the skids on each side, and weakened the deck even more.
I'm not sure how I bent it. How would you bend a mower deck? I may have done it backing up into inclines that looked awkward to go forward into (or were inaccessible the other way) to try to hit the grass, but I don't know.
My acreage has mostly flat land, but there are a few fairly steep banks and such, some areas that are forested AND steep (those are some of the ones I back into, to cut up to the tree line).
Does anyone have any tips on how to not ruin a brushhog? How do you mow banks? Is it a bad idea to back up with the mower low?
edit: oh and one more question: I hit something like a brick or a rock or something (I don't know, didn't see it) and it pierced the side of the brushhog on its way to the next county. Is this just a crummy brushhog or is that normal?
   / How to brushhog uneven terrain without damaging equipment #2
If I'm going to back mine into thick stuff on an UP incline, I generally raise it up, then back up, then drop it down onto its victims. I have bent a tailwheel frame backing into stuff, but not the deck. Maybe just lucky? If you had a rock come right through the side of the deck, it sure sounds like a light gauge metal. Maybe you need a heavier-duty hog?
   / How to brushhog uneven terrain without damaging equipment #3
Rotary Cutters trail far behind the tractor. There is a limit to how well Rotary Cutters can traverse swales or back up banks.
(However, you should check that your PTO shaft is not too long, stressing the entire mower when it is compressed. Backing up banks will compress the PTO shaft if it is too long.)
VIDEO: tractor PTO shaft - YouTube
I use a HydrauLink Top Link between my tractor and my Land Pride Rotary Cutter.
VIDEO: hydraulink - YouTube
Weightier Rotary Cutters are more robust than light Rotary Cutters.
Finish Mowers have two belt powered spindles operating off the PTO powered gearbox, reducing their trail behind the tractor. If you mow regularly and can forgo mowing saplings and brush, consider a Finish Mower.
VIDEO: tractor finish mower - YouTube
Smoothing the pasture is another option. A Disc Harrow trailing a Chain Harrow is an effective combination for moving dirt from high spots to low spots.
   / How to brushhog uneven terrain without damaging equipment #4
I have a hydraulic top-link and use it to facilitate how JRobyn does and agree your deck sound too thin.
Some people use chains to replace the top link or down supports on the cutter, but I've never tried it.
So you don't really try to cut anything when you're going backwards up the hill, you just cut on the way back down... I could see how backing up a hill could kind of jam the implement into the hill and maybe bend it.
I'd like to have a heavier duty one but I don't really have the money to spend on it.
So I guess the more conservative, correct approach would just be to raise it up all the way while backing up to keep it clear of everything, then lower and roll forward? I can't think of a way that I could possibly stress the frame while dragging it forward.
I'll keep that in mind, it's mostly just 5% of the pasture I'm worried about though. Basically the ditch that runs in front of my acreage and an awkward area in a corner that runs up to the fences and has lots of trees and banks, with almost no room to turn.
   / How to brushhog uneven terrain without damaging equipment #7
Tractor supply sells a chain attachment, actually 2 chains the fasten to each lift arm and the to the top link attachment point on your tractor. This allows the bush hog to float up more so than the third arm will allow and also used the tail wheel to keep the height more uniform when traversing ditches, swales etc. I would recommend these for mowing hilly property. You need to watch the PTO shaft when raising the bush hog to extreme up limits, you could bind the PTO shaft or even bend it. Make sure you have plenty of clearance for the shaft to compress also or you could end up shoving the tractors PTO shaft into the tractors internals.
As for knocking a hole in the side with a rock or other hard object, your bush hog has too thin material. I had a light weight Howse BH once that while never penetrating the side, it did round it out from numerous rocks hitting the sides. Even 1/4" thick plate can be dented pretty good from a rock missile being tossed into it. Don't worry, a hole in the side wont affect the cutting ability of the BH.
   / How to brushhog uneven terrain without damaging equipment #8
Sounds like a light duty mower not really a bushhog (that being a brand really). Now another thing is how fast were you moving backwards? If you are slowly moving to the rear, I would think that you could control mower and keep from ramming the hill. If you are going in reverse at a fast clip, then all bets are off. Even with a good mower.......
   / How to brushhog uneven terrain without damaging equipment #9
I forgot to mention that the chain attachment also allows you to adjust the ride height of your mower so you don't have to continually readjust it when raising/lowering etc. This is especially important for tractors whose 3 PH don't stay in the same place or leaks down.
   / How to brushhog uneven terrain without damaging equipment #10
If you are in a wooded area, or if stumps are around, it is not uncommon to hit, dent, or possibly bend the sides of some cutters while making share turns. The cutter hangs out so far behind that sharp turns will swing it way out to the direction opposite your turn.
I've accidentally smashed into some stumps and trees in tight quarters a few times, and there is a LOT of force and unexpected shock imparted to the cutter and tractor as well. Good way to wake you up from the hypnosis one sometimes falls into while cutting a larger area. ;)
2018 CATERPILLAR 308E2 CR EXCAVATOR (A52709)
2018 CATERPILLAR...
24in pin on tooth excavator bucket (A56435)
24in pin on tooth...
2002 Bobcat 763 Compact Skid Steer (A56435)
2002 Bobcat 763...
2012 International Derrick Digger (A55973)
2012 International...
2008 FORD F-350 SUPER DUTY BUCKET TRUCK (A58214)
2008 FORD F-350...
SCAN TO RECEIVE TEXT UPDATES (A52709)
SCAN TO RECEIVE...
