Is there something wrong with my septic tank?
/ Is there something wrong with my septic tank? #1
prichard
N. Georgia
B2601 FEL
This dead grass is the exact outline of the tank. It has been a bit dry and there's only 6" or so of dirt above the tank but we've had worse dry spells and never seen this.
uploadfromtaptalk1466992096636.jpguploadfromtaptalk1466992103663.jpguploadfromtaptalk1466992109210.jpg
/ Is there something wrong with my septic tank? #2
Kind of odd, at least it isn't leaking!
Nope. Bone dry.
/ Is there something wrong with my septic tank? #4
That's normal heat from the tank is drying out the dirt as there's very little cover over the tank. Another words your tank is working.
Cool. Thanks
/ Is there something wrong with my septic tank? #6
Yep, and if you didn't know exactly where it was before you sure do now! :)
I found the opposite to be true regarding my French Field... always green during times of drought.
/ Is there something wrong with my septic tank? #7
Normal,mine do it every year in the summer months.
/ Is there something wrong with my septic tank? #8
Same here, mine looks the same when it is dry.
Thanks all. 1st I've seen that happen. Guess I need to water. Maybe we'll get rain again someday. Seemed like it would never stop in spring.
/ Is there something wrong with my septic tank? #10
And yep, we had the same thing in Navarro County, Texas.
/ Is there something wrong with my septic tank? #11
Reminds me of our septic tank days. Ours did the same thing; a water sprinkler every other day will take care of it...or put some more dirt on top.
/ Is there something wrong with my septic tank? #12
Salt from water softener , chlorine from laundry and antibiotic soap is killing the vegatation. My system shows a distinct green outline .
/ Is there something wrong with my septic tank? #13
If it's that dry I would worry about the tank settling and braking the inlet or outlet pipe.
/ Is there something wrong with my septic tank? #14
Mine's exactly the same. You probably have risers installed to make it easier to access the tank lids, and that's a good thing. They are usually 12-24" tall, your actual tank is much lower.
Having the tank pumped will require just removing dirt over the risers, not sure that adding dirt is the best idea.
/ Is there something wrong with my septic tank? #15
Mine looks the same way also. It has 7" of soil over it and bluegrass seldom grows over it. Crabgrass and a few weeds is about all i can grow there.
/ Is there something wrong with my septic tank? #16
Try monkey grass. It has worked well on top of and around my tank.
/ Is there something wrong with my septic tank? #17
Would be a bit of work, mix some hydrosource granules into the soil. It's a polymer that will absorb about 100X it's weight in water and helps to keep enough moisture in the soil between normal watering. Interesting stuff, a half teaspoon will soak up a 12 oz. glass of water.
/ Is there something wrong with my septic tank? #18
Mine looks similar most years, including right now. I usually point it out to my son and wife, and act surprised as I ask "why does the grass look so crappy there?" They just roll their eyes at me now.
I watered and will try to remember to do it every couple days.
Thanks all. This is what makes TBN so great.
/ Is there something wrong with my septic tank? #20
Heck, I don't even bother... it's the "rustic look".
In fact I just had it pumped a fortnight ago (first time in 20 years) and it took me a couple of minutes to dig the access hatch clear. :thumbsup:
