Anyone have a shop manual for a 50 HP Kubota? Need help.
/ Anyone have a shop manual for a 50 HP Kubota? Need help. #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have an M6800 Kubota and am trying to get the hood off. It's a tilt up style and I can't figure out how to get the hood off. A shop manual would surely help and if anyone has one maybe they could look up how to do it. It's easy, I think but there is some trick to it that I don't know. Thanks in advance.
/ Anyone have a shop manual for a 50 HP Kubota? Need help. #2
Are you trying to take it OFF or open it?
Go to Messicks and you can see the parts manual online.
/edit - I just scanned through the entire WSM and it only mentions removing the "bonnet" in two places. And basically just says remove bonnet.
/ Anyone have a shop manual for a 50 HP Kubota? Need help. #3
Reminds me of a 1937 Chevy shop manual I used to have. To rebuild transmission, it starts with "Place transmission on a sturdy work surface". Nothing about how to remove.
Got a manual and thank you Midniteoyl. I'm good to go now and will try to figure this out. I'll report back.
/ Anyone have a shop manual for a 50 HP Kubota? Need help. #6
Remove the hairpins at the hinge. Remove the arm that holds the hood up, then raise the hood high and then move it to the right side of the tractor. It well come loose from the hinge pins. It's kind of heavy and hard to handle. Get someone to help!!!! I forgot the wire for the lights.
That is excellent. Thank you.
7021 (A55851)
7021 (A55851)
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2021 FREIGHTLINER...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2014 Chevrolet Silverado 1500 (A60352)
2014 Chevrolet...
2015 Toro Z Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2015 Toro Z Master...
