Step by step for turning a large tractor tire inside out?
   / Step by step for turning a large tractor tire inside out? #11
Good Luck:laughing:
Success!!! My final attempt took about 2-3 hours...
I bolted a grain truck dual tire/wheel assembly to the top of my dirt scoop and used that as a stationary die. I then fabbed up some clamps on the sides of the tire and pulled the sidewalls down with chains using the pallet forks/front end loader. I couldn't pull from the back side, so I had to rotate the tire 180 degrees and finish up the other side. In my opinion, the end result has a very nice shape.
   / Step by step for turning a large tractor tire inside out? #13
VERY nice results,,, :thumbsup:
The only tire I have is the Michigan loader tire I flip inside-out by hand 20 times a day for exercise,,,
It is the only way I can stay looking like Dwayne Johnson without using steroids!! :eek:
(( have occasionally told a tall tale,,,,)) :laughing:
   / Step by step for turning a large tractor tire inside out? #15
Nice. I guess you were determined to geter done. What did you use to make the cuts with?
   / Step by step for turning a large tractor tire inside out? #16
That looks a lot like how we used to do it. We had a large round tank - 45" diameter or so that we put up next to a large tree and put the bead side of the tire next to it. Then we put one chain inside the tire and put two more chains on hooked to the first - to a tractor on the other side of the tree and back to the first - so we basically had four points of pulling the tire against the tank. they popped right through. We probably had forty of these as we used them for cattle feed bunks.
I used a sawzall with a metal blade (fine toothed)
   / Step by step for turning a large tractor tire inside out? #18
Yes, I do too. Good job. It reminds me of an artichoke some what, and will look nice full of flowers.
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2015 Ford F-150 Ext. Cab Pickup Truck (A55788)
2015 Ford F-150...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
2010 Toyota Prius Hybrid Hatchback (A53424)
2010 Toyota Prius...
2011 Western Star Trucks 4900 Tri Axle Truck, VIN # 5KJNALDR4BPBA7822 (A54865)
2011 Western Star...
2015 Ford Econoline Shuttle Bus (A55788)
2015 Ford...
