Any lubricant for undoing galvanized pipe?
/ Any lubricant for undoing galvanized pipe? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I've a 50 year old bathroom I'm working on.
I need to move the water shut off valve over about 4" so it does not hit the divider in the new vanity. The vanity has about 3" of "clearance" from the wall.
The valve is connected to a short (about 4") piece of galvanized SCREW IN connecting through the wall and screwing in to what looks like a galvanized or brass tee.
My "plan" is to come out with a shorter piece of galvanized, do a 90 degree, run it for a about 4" and put in a new shutoff valve.
I'm pretty sure it's been setting about 50 years. I anticipate it's stuck. Besides using good pipe wrenches is there anything like PB blaster or Kroil for plumbing I could spray on to "loosen" it up?
I don't want to use a torch too heat it up because of all the tinder dry 50 year old framing. And I don't want to wet the framing down for fear of mold when I close up the holes I'm making.
/ Any lubricant for undoing galvanized pipe? #2
Well with 50 year old pipes in my experience if they don't come loose they break off. I would keep an extractor handy and tap to clean up the threads.
/ Any lubricant for undoing galvanized pipe? #3
Any way to neatly notch around it?
Unless I can support the elbow or T my experience is 50/50 as to damage when taking apart.
Sometime the nipple actually crushes.
/ Any lubricant for undoing galvanized pipe? #4
You won't be able to get any lube in those threads because they have pipe dope on them. You'll probably smash the pipe a bit before it comes out with the force of the wrenches because steel pipe is malleable. Just use the biggest wrenches you can get on the pipe and the fitting it's screwed into and use opposing force. Cheater pipes on the wrenches often help. It will come out unless weakened by rust. Go back together with brass fittings.
/ Any lubricant for undoing galvanized pipe? #5
M y house was built during World War II. No copper pipes in the house either. Hard water had choked the pipes down to a pencil sized hole. I would change the inside of the cabinet if possible.
/ Any lubricant for undoing galvanized pipe? #6
Think positive go slow and it will come right out.
/ Any lubricant for undoing galvanized pipe? #7
Agree with this!
/ Any lubricant for undoing galvanized pipe? #8
I did quite a bit of rework on my 66 year old galvanized piped house. The original installer used massive amounts of pipe dope so they always turned off. Replaced sections of the house with copper as I went, however. Eventually did the whole house. As was mentioned in a prior post, lines this old were pretty choked down.
/ Any lubricant for undoing galvanized pipe? #9
There are a lot of kinds of pipe dope. Some kinds harden like a rock and others stay like grease. Some of it is more like glue and almost eliminates the possibility of taking it apart decades later.
It's always good to go to copper when replacing old iron pipes. Simply screw in a brass nipple as a transition piece to go from steel to copper and all the galvanic problems of copper to steel go away. A dielectric union accomplishes this too, but is not as good.
/ Any lubricant for undoing galvanized pipe? #10
I've replaced a lot of galvanized when the opportunity presented itself.
Most of it dates from 1922 and if it was not for remodeling... it would all still be there.
Inside is clean as a whistle... going on 95 years!
/ Any lubricant for undoing galvanized pipe? #11
I've seen that too. Sometimes it's severely corroded and sometimes not.
/ Any lubricant for undoing galvanized pipe? #12
I'm guessing the quality of water, quality of the pipe and exposure to environmental extremes...
Water is generally snow melt here and the climate mild... freezing temps not likely...
/ Any lubricant for undoing galvanized pipe? #14
I have had some pretty good luck using my 1800 watt heat gun in areas I wasn't comfortable with fire. Wont get it cherry of course, but it still helps. Not with galvanized tho, in our area it crumbles.
/ Any lubricant for undoing galvanized pipe? #15
I'm with the group that suggests modifying the vanity to clear the valve.
Well that's a small "group" :)
The pipe is old and if it proves to be aging badly I will probably have to do replacements in three bathrooms. I've already had to replace two drain fittings where they enter the wall due to the galvanized union rusting out.
As far as modifying the vanity that's pretty much a no-go.
/ Any lubricant for undoing galvanized pipe? #17
It might provide peace of mind to carefully cut out a square of drywall.
This way you can support the elbow to make your change and then reinsert the drywall with a little fixall...
/ Any lubricant for undoing galvanized pipe? #18
I would just put a couple wrenches on it and see. It is not like it has been sitting in the elements.
Do not screw copper fittings into galvanized. Dissimilar metals cause corrossion.
Nothing wrong with galv, it is just that people don't want to thread it. I threaded lots of pipe in my 20s.
I think you are worrying about this to much, and should have done it.
/ Any lubricant for undoing galvanized pipe? #19
Just put a wrench on it, crap sake. It is just a pipe, in the bathroom
You act like you are working on a model A car.
/ Any lubricant for undoing galvanized pipe? #20
Do I have to drive over and do this?
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61306)
2021 Takeuchi...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A59230)
2012 Ford F-550...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
