Ford 1700 4x4 front tires
   / Ford 1700 4x4 front tires #1
nsmithnd
Bismarck, ND
Ford 1700
Have a 1700 4x4 with loader, and one of the front (badly weather-checked) tires gave out this past weekend.
Was surprised to see they are only 4 ply rated around 750 lbs load.
Am hoping to replace them with something not quite so aggressive as they tear up the lawn pretty bad being narrow (6.00-16) ag tires.
Not seeing much variety out there in that size beyond ribbed tires and the same ag tires that are on it now.
Has anyone found an alternative that might be closer to an industrial style tire?
I noticed there are some (vintage) Jeep truck tires available that might work.
Any input would be greatly appreciated.
   / Ford 1700 4x4 front tires #2
Keep the front/rear ratio shipped from the factory. If you go turfs/r4 on the front, you may have to change the rears.
   / Ford 1700 4x4 front tires #3
When I had one go on my 1700 I just replaced both with the same size AG tire. The 1700 doesn't do half the damage my 1920 does to the lawn
Decided to go with a pair of 6 ply replacements in case I trade it in on a hydro-static some day.
I think the lugs are closer together and about half the height of the old ones (maybe just wishful thinking on my part).
   / Ford 1700 4x4 front tires #5
How much did those run you ? I have originals on my Ford 1900 that are pretty weather checked.
Steve
They started out at $70 each, then new tubes, labor, tax, and disposal fee brought them to $109 each.
   / Ford 1700 4x4 front tires #7
What size are the ones you removed?
   / Ford 1700 4x4 front tires #8
What size are the old rims?
   / Ford 1700 4x4 front tires #9
I would like to get your old ones
   / Ford 1700 4x4 front tires #10
Do you still have the old rims? Please respond to my email johnsonrod2@aol.com
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
2015 Ford Fusion S Sedan (A55853)
2015 Ford Fusion S...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
Honda EM3500SX Portable Gasoline Generator (A55851)
Honda EM3500SX...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
1607 (A57192)
1607 (A57192)
