Branson hard to start, lots of smoke
   / Branson hard to start, lots of smoke #31
Not getting all your history, like age, usage, you original owner or prior owner habits. Winter time is hard on engines, even in Georgia or Texas. Condensation is a problem in that you have a lot of iron to get hot to get the oil hot to drive out condensation which is always there on cold days. If you continuously run your tractor for short intervals you will have a buildup of moisture and gray to chocolate oil depending upon the level of contamination.
As stated, pumping the throttle on a diesel is not like on a gas engine. What you are actually doing is changing the amount of fuel getting to the injectors. White smoke is water vapor; blue is oil, and black is dirty injectors/engine overloaded. Water in the winter is condensation from running the tractor for short periods and not giving it time to warm up and drive out the moisture. Happens all the time. Yes you are puking diesel by letting it run and not doing any work with it, but in the long term it is cheap insurance. I do and I am not on here complaining as you are. Get the point?
Before you jump to any conclusions, get your tractor out and put a piece of cardboard in front of the radiator thus blocking the air across it and allowing the coolant to get hot. Crank it up and pull the throttle to max. Let it run like that sitting stationary at WOT rpm for 30 minutes monitoring the engine temp while doing that. What you want is to have the engine temp get up to around midrange and stay there long enough to heat everything up and drive out the moisture. Obviously you don't want to red line it.
PS makes some good diesel additives that can help with winter operation. WW and tractor supply stores stock them along with other additive mfgrs. There are the users and the denyers. I am a user and no way would I be a denyer as additives have proven themselves time and time again to me. Buttttt additives can help combustion and fuel hygiene and all that, but condensation in the engine has to be burned out.
If you do what I said and come back the next day and still have problems, I'd be looking for water in the fuel. But I'm not there so I can't first hand help you to analyze your particular situation.
HTH,
Mark
   / Branson hard to start, lots of smoke #32
Has anybody suggested reading the operator's manual ?
Seriously Are People on this site Real ? Branson Manual says one thing clearly, Authorized Dealer for Repairs. Which cost You $225.00 for Them to transport [under warranty] and then 10 to 23 days for simple repairs.
   / Branson hard to start, lots of smoke #33
jrv4real: Dude. Classic blunder. You responded to a very old thread: 2013. Watch those dates. I know I've certainly been tempted when I see dumb responses. :)
   / Branson hard to start, lots of smoke #34
Dude ??
Where in my comment does age of thread change any factual statement ?
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
John Deere Gator (A53317)
John Deere Gator...
2012 International ProStar T/A Day Cab Truck Tractor (A56858)
2012 International...
2017 Freightliner Derrick Digger (A55973)
2017 Freightliner...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55315)
2023 Kubota...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
