John Deere 430 baler belt tension bar will not lower allowing gate not to close
   / John Deere 430 baler belt tension bar will not lower allowing gate not to close #1
Glummus
Atlanta, texas
John Deere 430 hay baler
I have a 430 John Deere baler. When the bale is made the gate will open allowing the bale to be discharged but the gate will not close back. I noticed that the bar that takes the slack out of belts was not lowering. Cylinders on each side that allowed it to lowere were not working. After putting the locking valve in and out several times and raising and lowering gate I could eventually get it to work but it was doing it every time I made a bale. Any help would be appreciated.
   / John Deere 430 baler belt tension bar will not lower allowing gate not to close #2
:welcome:
I'm going to move your thread over to our John Deere section to see if we can find you some help with that.
   / John Deere 430 baler belt tension bar will not lower allowing gate not to close #3
Welcome to TBN
What model tractor are you attempting to operate baler with? Have you tried disconnecting/reconnecting hyd couplers between tractor & baler? How much pressure is showing on baler gauge after core is formed?
Welcome to TBN
What model tractor are you attempting to operate baler with? Have you tried disconnecting/reconnecting hyd couplers between tractor & baler? How much pressure is showing on baler gauge after core is formed?[/QUOTE. I will check pressure on the next hay that I bale. I do think you are right that the pressure may be to low. When handling the bales the string comes off and the bale is to loose. I think I have eliminated the problem with the gate not closing. I pressure washed baler and cleaned it up good. The gate then started working fine. Thanks for info.
   / John Deere 430 baler belt tension bar will not lower allowing gate not to close #5
Thanks for update but I seriously doubt pressure washing is the reason TG started closing
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A51039)
REYNOLDS 100 - 8...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A49461)
1993 Ingersoll...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2012 KENWORTH T800 SLEEPER (A50854)
2012 KENWORTH T800...
3 1/2 BLACK CONDUIT WITH ROLL OF FABRIC INNERDUCT (A50854)
3 1/2 BLACK...
