Comparison 3-point hitch identification
/ 3-point hitch identification #1
JayRm
Little Compton, RI
Kubota L4060; Kubota RX1100
How does one determine whether, or not, the 3-point hitch on a Kubota L4060 is a category 1 or 2?
Also, is this tractor considered a "Grand" L or a "standard" tractor?
Thank you.
Jay M
/ 3-point hitch identification #3
If it has this Trans I would say it's a grand L. HST Plus
Type: hydrostatic
Gears: infinite (3-range) forward and reverse
Hydrostatic transmission with three ranges plus Hydro Dual Speed Hi-Lo. The Dual Speed allows rapid switching between two speeds in range, either automatically or with a lever on the steering column.
/ 3-point hitch identification #5
The last two digits in the model number xx60, indicate it is a Grand L of the current series.
/ 3-point hitch identification #6
3PH is category 1.
Lower arms should measure just a little over 7/8" for cat I and just a tad over 1-1/8 for cat II
/ 3-point hitch identification #8
L series will be a cat 1. Unless they have changed they do not have cat 2 till you hit M series. The pins in the lift arms are 7/8 inch on cat 1 and 1 1/8 on cat 2 if Friday afternoon brain is not clouded.
/ 3-point hitch identification #9
I think the upper two GrandL's have a cat I & II. Like the L6060. Really is too much tractor for most cat I implements.
/ 3-point hitch identification #10
My Grand L 5740 is a Cat 2 as was the one below it. SAE standard is 50 HP and up (can't remember the 2 to 3 HP switch) Cat 2. Kubota follows the standard although some others (Deere in particular) don't. The Cat 2 Kubotas are actually Cat 1-2 in that the arms will swing in to Cat 1 position and you can get the bushings for Cat 1 to Cat 2 in any farm store. Our JD 6230 for example will not allow the draft arms swing into the Cat 1 position. Our 7720 Deere, however, is Cat 3 but the arms can move to Cat 2 and we use Cat 2 implements using bushings.
/ 3-point hitch identification #11
Well sorry for my errors on cat two. Looking on wikipedia they show good chart.
En.wikipedia.org/wiki/three-point_hitch#size_categories
But as has been pointed out all brands do not hold firm there.
ALLMAND MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
TIRE RACK WITH TIRES (A68842)
TIRE RACK WITH...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
Shop Cart (A68134)
Shop Cart (A68134)
