Deere 455 mower deck travel
/ Deere 455 mower deck travel #1
steve74
Carlisle, PA
Deere 345
I recently acquired a new to me 2001 deere 455 with 700 single owner hours on it. The guy mowed with it, then his son in law mowed for him until he moved out of the acreage. My question relates to the deck lift. In my case, full travel on the deck seems to only be about 1.5 inches. Before I start taking anything apart or digging in to it too deeply, is that typical, or is there something obvious I should be looking for - some kind of well known fault?
Thanks
Steve
/ Deere 455 mower deck travel #2
I had a 455 many years back, and I recall that same limited deck lift. Have a hunch, that's as designed.
/ Deere 455 mower deck travel #3
Are you adjusting the height of cut at all? Max height is usually around 4" and if yours is set at 2.5" there will only be 1.5" of travel.
I haven't really messed with anything yet - it just came off the trailer yesterday. The height adjustment knob is gone, there's just a big hex bolt (maybe 1.25 in) in the hole where it should be so I really have no idea what it's set to.
with the deck down it's at a reasonable mowing height - probably about 2.5 in. Mostly I'm trying to figure out if there's a way to draw the deck up higher for non-mowing tasks - there are definitely things I do with my 345 that would result in gouging or general deck abuse if I tried them with the deck that low. For that matter, if I can't raise the deck more than that I'm probably going to end up grading some hills in the lawn with the mower.
I suppose as long as I'm not hitting the stops under the tractor, I can tighten the yokes up a bit, maybe even adjust the lift arms. Are there interferences (other than the stop) that I should be concerned about under the tractor?
To close this up (perhaps) I popped the deck off, which went better than I thought, and discovered 1) it would appear the bar that runs from the rear to the lift lever is jamming on the rod for the brake. But in any even the lift arms weren't coming to full lift. So I pulled the arms off, rotated them about 30 degrees, reinstalled so the arms are at the top of travel, and everything seems fine. We'll see how things work.
Steve
/ Deere 455 mower deck travel #6
I remember one of my first jobs was at Nashua Outdoor Powerequipment. Back then the 455 was the biggest Deere they sold. Fast forward now and they sell upto the 5 series family. I remember prepping all the units and got to do a few of those 455 units, even put a loader on one. Those were very nice, and extremely well built. It's nice to see there still going out there, I'm not surprised though . Good Find!
My other tractor is a 950... Also running like a champ.
2018 KENWORTH T370 LUBE TRUCK (A65057)
2018 KENWORTH T370...
CAT 930 Coupler (A68134)
CAT 930 Coupler...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2020 Ford F-150...
2017 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65056)
2017 CATERPILLAR...
2018 GENERAC MOBILE PRODUCTS MTL6S (A68842)
2018 GENERAC...
2009 PETERBILT 388 FLATTOP SLEEPER (A67714)
2009 PETERBILT 388...
