4035 FEL control is sticking
   / 4035 FEL control is sticking #1
Sysop
Elite Member
Fairmont, WV
Mahindra 4035HST purchased 2013 - Husqvarna TS348-D purchased 2019 - Craftsman 42" HST purchased 2003
Anyone got any advice for the best method of handling it? Up and down are fine, curl is what sticks.
Thanks for any input!
   / 4035 FEL control is sticking #2
Mine started doing same thing and adjusting it did not help. I took the cable off and it was hard to pull it through because of a burr in it. I replaced cable and problem solved. Hope this helps.
   / 4035 FEL control is sticking #3
I had some corrosion under the caps of the loader control valve. pull the caps off the valve by removing the 2 allen cap screws. hose out with wd 40 and reassemble.
   / 4035 FEL control is sticking #4
Thats usually where I start.Once its cleaned I like to lube it up with grease. Careful on the lift spool if you check that one. Don't loose your detent spring and balls. :thumbsup:
   / 4035 FEL control is sticking #5
" I lost my balls, in Fairmont West Virginny.... High on a hill, they call to me.... " [ Tony Bennett singing in the background... ]
2017 Polaris 500 Ranger Diesel (A50324)
2017 Polaris 500...
MEGGER EZ THUMP (A50854)
MEGGER EZ THUMP...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
