LED light install on ROPS using Magnets on NH Tractor
   / LED light install on ROPS using Magnets on NH Tractor #11
mount the leds at the front of the bucket arms on the side so they face somewhat downwards. that way they are not behind you, they face the work and when the bucket is up they still light the ground in front so you can see where you are going. PS... never a good idea to drive with a loaded bucket high anyway!!!
   / LED light install on ROPS using Magnets on NH Tractor #12
These are the magnets you want
Magnetic Round Bases | CMS Magnetics
$3.24 apiece and shipping is relatively reasonable. Cheaper than amazon.
Well for the individual magnet they may have been cheaper :)
BUT since they were so inexpensive I ordered 10 w/ the 1/4-20 stud, and just had to also toss in a 405 LB Holding Power Neodymium Cup Magnet 2.95" Magnetic Round Base for another $27. Then I had to order a flat head bolt for the big magnet, so I ended up buying 50 bolts on ebay. And I'll probably buy several more of the 405 LB Holding Power Neodymium Cup Magnet 2.95" Magnetic Round Base. (those things are POWERFUL).
mission creep.
I have thought about moving them to the front or even adding a light bar to the grill protection. Only problem with this is I use the FEL quite a bit to dump limbs in the fire pit and the lights would get damaged. I really only have a problem with glare of the lights when I am wearing safety glasses and looking backwards. Otherwise they work great on the ROPS as I am able to angle them anyway I want since they are mounted using the magnets.
mission creep.
I cannot believe how much stronger the Neodymium magnet is compared to the traditional magents. I have been using mine for the past couple of weeks and they havent budget. It actually takes both of my hands to even get them to slide to a different position on the ROPS . I use my tractor to cut grass and my field is quite bumpy and I even go under low branches that contact the lights and they still hold strong. I am definitely going to place another order.
I am interest in the 405 Lb magnet that you purchased. Would you please provide a link? I need something to drag over the top of my burn put to locate screws and nails that the previous owners so kindly left.
Its amazing how a simple search can get you almost twice the product or more on ebay or amazon (usually from china) for the price one would cost at the hardware store (which is also made in china).
   / LED light install on ROPS using Magnets on NH Tractor #14
<snip>
I am interest in the 405 Lb magnet that you purchased. Would you please provide a link? I need something to drag over the top of my burn put to locate screws and nails that the previous owners so kindly left. <snip>
Linky
   / LED light install on ROPS using Magnets on NH Tractor #15
Don't mind me. Just following this thread. I am going to want to add work lights to my Boomer 24 this summer in anticipation of snow plowing in the dark winter months.
   / LED light install on ROPS using Magnets on NH Tractor #16
image.jpegI added light bars on my Ford because the ROPS had a natural place for them and neither bothers the operator. Those you got look handy for a lot uses. I think I might get some just in case.
View attachment 470843I added light bars on my Ford because the ROPS had a natural place for them and neither bothers the operator. Those you got look handy for a lot uses. I think I might get some just in case.
wow great install with the light bar! I have a 22in sitting on my shelf waiting to be installed somewhere.
Lights are still holding strong on mine using the CMS magnets. They stay on over rough terrain and against trees brushing against them.
I also picked up the 405lb magnet recommended by Newbury above. I have been using it to pickup screws in my burn pile. I have an extra pole and some gopro mounts I plan to make a holder for it. Definitely picks up anything metal with a quick swipe above the ground.
Got bored this weekend and put together a little device for the 405lb neo magnet from CMS . This little guy works insanely well to pick up the metal in my burn pile. I am thinking it would also be good to hang up a shop light in the barn when I winterize the boat this summer. Part #MCHN-75
   / LED light install on ROPS using Magnets on NH Tractor #19
Most of my lighting on my CUT is mounted using magnets.
Advantage is in re positioning for maximum results without drilling holes.
Also if snagged you simply re attach without damage, =win win.
   / LED light install on ROPS using Magnets on NH Tractor #20
This is a great idea as I broke off my old bases three times in the woods!.
Just purchased two Rare Earth magnets on Amazon: Manic Magnets 75 Lbs Pull Force (2 Pack), 1.26"Outside Diameter, CounterSunk Hole for #10 Bolt Size, Rare Earth Neodymium
And a 36W 8" light bar. I was happy with the 18 I had but no reason not to go bigger and it has end mounts instead of one center mount. 36w LED Work Light Bar 12v Flood
That magnet place looks great! Neodymium Disc Magnets with Countersunk Hole | CMS Magnetics
2021 Ford F-250 Crew Cab Pickup Truck (A55852)
2021 Ford F-250...
UNUSED PABREAK RGB240 - 84" ROCK GRAPPLE BUCKET (A57193)
UNUSED PABREAK...
1837 (A51248)
1837 (A51248)
Year: 2016 Make: Chevrolet Model: Tahoe Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 104,678 (A56859)
Year: 2016 Make...
UNUSED LANHERO LDH-SP50 50 TON HYD SHOP PRESS (A57193)
UNUSED LANHERO...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
