What to look for in a compound miter saw?
   / What to look for in a compound miter saw? #51
Alot of times I dont even mark a board when using my miter saw. (Mine dont have a laser either.)
Rather I'll clip the tape on the left end of the board, string it past where I need to cut, and lock the tape. Lower the sawblade (not running) and line up precisely with the tapemeasure. Then holding the board firm to the back of the saw with my left hand so it dont move, remove tape with right hand and cut.
Kinda hard to describe, but IMO its easier, and more precise, than marking then cutting
I often do the exact same thing. I never understood how the laser line could do anything for me.
   / What to look for in a compound miter saw? #52
If cutting angles and you have them marked with a line the laser may give confirmation accuracy of the saw settings.
   / What to look for in a compound miter saw? #53
Yea, I can see that.
But my confirmation is lowering the saw, (not running) and sliding it across the cut line. If the saw teeth walk perfect down my marked line, good to go. If not, adjust as necessary
   / What to look for in a compound miter saw? #54
Exactly, and since the lasers usually only come on when the saw blade rotation is started I don't see how they can be of any use. In fact they would be more dangerous to have the laser come on and project its line, but now you have a whirring saw blade spinning in free space while you are shoving a workpiece around with you hand trying to make the blade cut line line up. It all just does not make any sense to me. Am I missing something here?
It just seems so easy to line of the saw teeth for the exact cut you want without turning on the saw or having your trigger finger anywhere near the switch. It seems safer to me. Not to mention the method outlined by LD1 in an earlier post of not even marking the workpiece at all with a pencil mark but just using the tape measure to find your cut line.
   / What to look for in a compound miter saw? #55
Every laser saw I've used always stays on.
If they are set properly and accurate they are much nicer for production cuts. If you're doing trim in a house it'll save at the least a few seconds every cut. Over a fee hundred cuts you've saved a lunchbreak of time. That can be each day trimming out a home.
Time is money. Lasers are a great tool when used properly. They have also gotten better. Ten years ago they were gimmicky but most saws now they are tip top.
Don't need to lower saw and bend and look. Just slide board in and you see the line. Match with your pencil line and cut.
   / What to look for in a compound miter saw? #56
I have one of those laser addons and it works well for me. My saw has a blade guard so there is no safety issue. Just turn the saw on, the laser marks the cut line, slide the workpiece with my cut mark to the laser line then either clamp or hold and make the cut. Easy peasy and spot on every time.
   / What to look for in a compound miter saw? #57
Don't buy a laser. The laser bleeds on the edges and is super hard to see. Every tool I have that has a laser also has duct tape covering the laser so I can accurately follow a line.
   / What to look for in a compound miter saw? #58
Eric you need a new laser or new eyes. Lasers are bright in daylight and have gotten better, I'm telling you. uploadfromtaptalk1463115912999.jpg
   / What to look for in a compound miter saw? #59
u
Can you do that with a compound miter cut?
   / What to look for in a compound miter saw? #60
I have used a sliding bevel Bosch for over 20 years and various simple miter saws too, currently a Hitachi. Never a laser. Count me as a skeptic. What could be simpler, or more accurate, than lining up a left leaning tooth with the right side of your pencil mark? A laser line has to have some width, otherwise you could not see it. So by definition it is just another source of measurement error no matter what the alignment might be.
2013 John Deere 27D Mini Excavator (A55973)
2013 John Deere...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2025 BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
Push Mower (A55973)
Push Mower (A55973)
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
