What to look for in a compound miter saw?
   / What to look for in a compound miter saw? #41
True. Nothing like looking afterward and seeing it lying on the floor.
   / What to look for in a compound miter saw? #42
Some time in the 80's, the guy beside be was being trained to run a metal cutting bandsaw. He didn't last 15 minutes before he cut his left thumb off. The set-up man was standing right beside him when it happened and later said he nearly lost his breakfast.
   / What to look for in a compound miter saw? #43
I'm in the market for a miter saw. I have a variety of projects coming up that will make one very very handy but I don't really know what I need. I'll be facing some exterior deck stairs (risers), building a trellis and a small picket fence, probably building some interior, simple book shelves and building bed rails for the pocket stakes on my trailer, etc. etc. etc.
Yes, I could be doing a lot of this with a circular saw, and I always have, but I think I'd get better results, faster, with a sliding chop saw.
I will not be cutting much, if any, molding.
I'm pretty sure I want a 12" and fair power (15 amp?) as I will be cutting some treated lumber and possible some 4x4s. I want the sliding type as well.
Other than that I don't know what to look for. I don't even know what single bevel vs double bevel means. Any advice much appreciated.
I really like my 12" Milwaukee compound slider saw. I have it mounted on a Bosch gravity rise table which requires no bending over whatsoever to set up.
I've seen, but not tried to use the new all gear Bosch compound slider saw, and that interests me, but my Milwaukee has a neat digital readout that makes fine, finishing trim cuts work well. Moreover, I like that the mitre is set on ballbearings so it literally glides.
I've had my saw since 2007 or 2008. You can read the reviews at Amazon. Milwaukee 6955-2 12-Inch Sliding Dual Bevel Miter Saw with Digital Miter Angle Fine Adjust - Power Miter Saws - Amazon.com
A saw I'd look at is the new Bosch. I'd miss the digital read out for finish work, but the Bosch saw my be the hot ticket for what your intended use is.
GCM12SD | 12 In. Dual-Bevel Glide Miter Saw | Bosch Power Tools
No matter what 12" saw you get, mate it to a Bocsh gravity rise table. Trust me on this!
Bosch T4B Gravity-Rise Miter Saw Stand - Power Tool Stands - Amazon.com
Someone early in the thread mentioned getting or building a saw table/stand. I skipped that and just made do when cutting long pieces but it is so much of a pain that all the efficiency of the saw itself is lost. The one in the video would be awesome but my budget was already stretched. I saw a Ryobi stand at a big box store for $99. It is cheap, no frills. No wheels and fairly heavy. However, it is very sturdy and folds down neatly so I'm pleased with it. If I were on the move with this sort of saw one of the ones like in the video would be worth every penny.
   / What to look for in a compound miter saw? #45
The best thing I ever bought with my saw was a stand. Mines an older model of this one. It's been worth every penny.
Ridgid Mobile Miter saw stand
   / What to look for in a compound miter saw? #46
I use my tailgate and an adjustable roller stand when on the job. At home, my workbench is lowered for my saw with 8 feet in either direction of bench to support what I'm cutting, and for longer stuff,there is 8 more feet of open air after the bench ends off to the right.
   / What to look for in a compound miter saw? #47
Wow! that Bosch stand is really something. If I was a carpenter and moving tools around I would have one of those.
As to the laser thing, I guess I don't understand it's usefulness. I have always just gently set the static blade down on the work to see where the teeth of the blade will hit on the mark. I don't understand how a laser could make this any better or more precise?:confused3: I just don't see the need for it.
   / What to look for in a compound miter saw? #48
James, my laser has never been accurate. Maybe it's adjustable but like you I don't see the point. Mark board, lower saw. Since you actually have to start saw to see the laser you'd have to wait for saw to stop or move board around under moving blade to adjust anyway.
   / What to look for in a compound miter saw? #49
That is what I thought.
   / What to look for in a compound miter saw? #50
Alot of times I dont even mark a board when using my miter saw. (Mine dont have a laser either.)
Rather I'll clip the tape on the left end of the board, string it past where I need to cut, and lock the tape. Lower the sawblade (not running) and line up precisely with the tapemeasure. Then holding the board firm to the back of the saw with my left hand so it dont move, remove tape with right hand and cut.
Kinda hard to describe, but IMO its easier, and more precise, than marking then cutting
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
John Deere 5055E (A53317)
John Deere 5055E...
2021 Ford F450 (A55973)
2021 Ford F450...
2003 Freightliner FL60 American LaFrance Ambulance (A56858)
2003 Freightliner...
Eaton Air Compressor (A56857)
Eaton Air...
2020 DRAGON ESP...
