Price Check Kubota 2003 ZD21 Zero Turn(s)
   / Kubota 2003 ZD21 Zero Turn(s) #1
KT7307
Clearwater MN / Hillsboro MO
Kubota L2650 4wd / ASV 4810 / XXW2500 Dixie Chopper / Scag Walk Behind
I'm located near St Louis MO and am looking at a very nice 2003 Kubota ZD21 (standard deck) with ~1000 hours for $4750.00. I'm happy with the $4750 and most likely will buy it. However, he has an identical unit with ~1000 hours that is missing the engine assembly. (no seat, roll bar, radiator, engine, mounts, etc...) This "parts" unit looks pretty good; tires, deck, drive shaft, rear hood, all there.
My question: would it be a wise investment to buy the parts tractor for $1,000.00. Also, would I be crazy to consider rebuilding the parts tractor? Would the more powerful 28HP DSL engine fit or maybe a cheaper air cooled gas model? I love to tinker with stuff, however don't want to get in over my head...
Thx in advance for your replies :)
   / Kubota 2003 ZD21 Zero Turn(s) #2
Awesome mowers we have them in our area with many more thousands of hours and still going strong. On the thoughts of 1,000 for the parts machine I'd say it might be a good investment for tinkering if you have the time and potential to spend a couple grand more for an engine, but then you might be able to buy a complete machine for the same dollar.
I pulled the trigger on the parts mower ($400) / However I got cold feet on the "running" mower B/C it wouldn't start when cold W/O a shot of carb cleaner. I'm looking at a early 2000's ZD28 for $6500.00 / Will post results :)
   / Kubota 2003 ZD21 Zero Turn(s) #4
ZD28 is great.
would also run away from anyone who feels they need to start those with carb cleaner! Probably not an easier starting diesel on the market than the D905 in that mower.
Has anyone had trans issues with their ZD21/28 transmissions? I came across a several posts about early ZD series HST troubles.
ZD28 is great. would also run away from anyone who feels they need to start those with carb cleaner! Probably not an easier starting diesel on the market than the D905 in that mower.
Thanks for the reply! BTW, I've purchased a few parts for my Kubota tractor from ya'll. Great service!
   / Kubota 2003 ZD21 Zero Turn(s) #7
The early units, before the ZD series had ROPS could run dry on really steep hills. This had a fix kit for it eventually. Beyond that, I don't know that we would see failure rates and worse than any other ZTR with a hydrogear or parker transmission.
2013 CAT 950K WHEEL LOADER (A50854)
2013 CAT 950K...
Tree Boom (A50322)
Tree Boom (A50322)
71054 (A49346)
71054 (A49346)
2020 INTERNATIONAL LT625 SLEEPER (A50854)
2020 INTERNATIONAL...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
Non running toro mower (A48082)
Non running toro...
