Part numbers for Kubota QA needed !!!!!
   / Part numbers for Kubota QA needed !!!!! #1
nc redneck
Apex nc
Kioti Dk45SE Sold Kubota BX 2200 Sold Kubota B 3200 Loader WR Long 4 in 1
I am looking for part numbers of Kubota pin on method of QA for B 3200. Down sizing from Kioti 45 with WR Long 4 in 1 to Kubota B 3200. B is a small tractor and will not do well with weight of standard QA. Also looking for any info on B 3200 owners with 4 in 1 . B is stock only 120 hours no remote it also has a LA 504 loader. Hard to give up 4 in 1 after having one. Not interested in a grapple.
Thanks
Scott
   / Part numbers for Kubota QA needed !!!!! #2
I have B1658 QA with LA504 loader. If I had to do it all over, I would find a Kubota to SSQA adapter, lots easier to find attachments for less cost.
Thanks I have installed SSQA part number B2366. I also have WR Long 4-1 bucket ordered plus valve. Almost finished converting stock 54 bucket to QA as others have done. Additional weight of QA does not seem to be a issue so far.
   / Part numbers for Kubota QA needed !!!!! #4
I'm in the market for the B1658. Do you recall the price? TY
I did end up with SSQA. I use with WR Long 4 in 1 and hydraulic forks. It was $ 600 from dealer and a bolt on install with LA504 loader as others have covered. It was about $ 300 cheaper than the ATI model I was looking at, probably better made and looks much lighter.
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
FENCE PANELS (A58214)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2019 KOMATSU D155AX-8 CRAWLER DOZER (A60429)
2019 KOMATSU...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
