squirrels in balcony and gutters, not in house yet.
   / squirrels in balcony and gutters, not in house yet. #21
SMOKE BOMB!! my new idea. Looks like a BIG firecracker. Light fuse and fills squirrels house with smoke.
I guess they leave because of smoke. I haven't tried one yet. I wonder if would set house on fire as the squirrels are living in wood balcony They found a spot
in boxed in steel beam holding up the outer part of balcony. How bad does the smoke smell is also a question, since its in outside part of house?
I have a 30 year old one shot pellet gun. I wonder if it even works anymore or if I could get pellets? I have to try it.
Any ideas.......Coffeeman
The smoke is toxic to people, too. Smoke bombs produce heat and sometimes flames. You may set your house on fire. If you kill the squirrel inside your walls, attic, etc... it will stink for a week or two really bad. And your house will smell like sulfur for a loooooongggggg time if any of it gets into your house. Best way is to seal up all possible entry ways.
   / squirrels in balcony and gutters, not in house yet. #22
Well.......setting your house on fire would solve the squirrel problem???????:shocked:
Im not so sure Nationwide would be "on my side".
Cheers.....Coffeeman
2013 Ford Fusion SE Hatchback (A55853)
2013 Ford Fusion...
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
2010 Ford F150 Single Cab Pickup Truck (A55973)
2010 Ford F150...
23105 (A56859)
23105 (A56859)
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A56435)
2023 Kubota Z412KW...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
