cutting-digging bar
/ cutting-digging bar #1
Cottage Grove, Wisconsin
Kubota MX5800
Looking for suggestions on which reliable, durable, effective cutting or digging bar I should consider for my Kubota MX4800 with LA1065 Loader. Thanks for any help.
/ cutting-digging bar #2
I'm assuming you mean loader tooth bar. I have had WR Long tooth bars on both of my tracotors so far and have been very impressed with them. Not a single issue ever with either one. Dug my pond with an L3800 with WR Long TB and Box Blade in red clay here. Loader did the bulk of the work. One of the best add-ons I could recommend.
/ cutting-digging bar #5
Google WR Long Inc. Then look at their STB series, which is for compact tractors with loader lift to 3,500 lbs. Comes in different lengths depending on your tractor. I bought both of mind through my dealer when buying the tractors. I think my L3800 was about $400 for the tooth bar. Money very well spent. Side benefit is these will keep your bucket from smiling. Really beefs up the leading edge and you can remove them if needed pretty easily too. You can replace the teeth individually if you ever need to, but I haven't ever worn one out.
/ cutting-digging bar #8
The LONG version looks just like the one I got from Bobcat. I like it a lot but hear a lot of good things about the Piranha as well. I think it really shines for brush clearing.
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
213213 (A64277)
213213 (A64277)
2006 PROCO 130BBL (A65643)
2006 PROCO 130BBL...
2021 SANY SY265C LC LONG REACH EXCAVATOR (A63276)
2021 SANY SY265C...
