CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 9,218
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
I've got a pair of torn and deteriorated tie rod end seals on the Hurlimann that I want to replace before the dirt takes out the ball joints.
It would be much more accessible to work on the tractor with the loader out of the way.
I could disconnect and back out, but it would be fine just to have the lift arms all the way up. The Allied loader has a little placard that describes how dangerous working under the raised bucket can be and how to be sure to install the safety struts between the cylinder head and the rod end.
Of course, those safety struts are not part of the tractor kit when purchased.
It would be easy enough to cut a couple of lengths of bed frame angle iron to replace the missing OEM units, but they wouldn't have the made to fit retainers. (duct tape might be a suitable alternative? ;-)
Last time I needed access to pull the front grill, after crushing it rolling root balls, I propped a 4X4 under the bucket and let off the hydraulics just enough to hold it all in place.
What's your favorite expedient? I haven't seen many loaders with the safety struts attached, Some, but not many. I have seen the placards on several units. At least those that have not set out in the weather too log.
