Working under the bucket?
/ Working under the bucket? #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
I've got a pair of torn and deteriorated tie rod end seals on the Hurlimann that I want to replace before the dirt takes out the ball joints.
It would be much more accessible to work on the tractor with the loader out of the way.
I could disconnect and back out, but it would be fine just to have the lift arms all the way up. The Allied loader has a little placard that describes how dangerous working under the raised bucket can be and how to be sure to install the safety struts between the cylinder head and the rod end.
Of course, those safety struts are not part of the tractor kit when purchased.
It would be easy enough to cut a couple of lengths of bed frame angle iron to replace the missing OEM units, but they wouldn't have the made to fit retainers. (duct tape might be a suitable alternative? ;-)
Last time I needed access to pull the front grill, after crushing it rolling root balls, I propped a 4X4 under the bucket and let off the hydraulics just enough to hold it all in place.
What's your favorite expedient? I haven't seen many loaders with the safety struts attached, Some, but not many. I have seen the placards on several units. At least those that have not set out in the weather too log.
/ Working under the bucket? #2
Bed frame angles would work fine but I would hold them on with wire or something a lot stronger than tape. If the scoop wanted to come down it all depends on the geometry how much side force is on the angle iron. Be safe! If it only takes a few minutes it would be quicker to take it off.
/ Working under the bucket? #3
Muffler clamps to hold angle.
/ Working under the bucket? #4
Don't tempt fate. Take off the loader. Never take a shortcut when it comes to safety. Just my $.02. You wont get a second chance if it goes wrong. The loader coming off probably takes less time than typing your question. Besides, you can grease it easier off.
/ Working under the bucket? #5
...What's your favorite expedient?....
I just raised the loader... and for that I hit my head walking into it. Next time I'll remove it. I've done that enough now that it's only a few minute job.
/ Working under the bucket? #6
Someone told me to fabricate a couple sleeves that fit over the extended cylinder shafts. I never did it YET, I just took my chances. So far I am 100% successful with my carelessness (Of course I am kidding about that). The sleeve should do the trick though.
I so know a 40 year old gal who raised a skid steer bucket and leaned into the cab. She accidentally hit the drop lever and it crushed her. Devastating. Be careful.
/ Working under the bucket? #7
I have to confess that I am guilt of raising the FEL on my tractors in order to open the hood and check oil, clean filter etc without blocking it. Safety demands that it be blocked with something strong enough to hold the weight without bending or bowing. Lots of things might fit that bill depending on the weight of your loader. Something as simple as a couple of 2x4 pieces of lumber wired onto the cylinder(one on top and one on the bottom or one on each side) might be sufficient also. Wood also wouldn't by chance scratch up your cylinder rod.
/ Working under the bucket? #8
For a homemade cylinder safety strut, I would cut a length of rectangular steel tubing lengthways to make a deep channel that could be strapped to the rod. Then test it before using. Rod end and loader shape may require more than a square end.
Bruce
/ Working under the bucket? #9
i have pulled mine up to my deckover gooseneck and set the bucket on the trailer bed and can then set on the ground and work on the tractors front end pretty easilly.
with bucket down pressure can lift the tractor front and slip jack stands under it if needed.
/ Working under the bucket? #10
That is about the smartest way yet.
John Deere 5075E (A60462)
John Deere 5075E...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
EXCAVATOR JACKHAMMER (A58214)
EXCAVATOR...
500BBL WHEELED...
John Deere 7810 (A60462)
John Deere 7810...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
