Remove the deck on a ZG222
/ Remove the deck on a ZG222 #1
JeffreyD
Guymon Oklahoma
Kubota ZG222
How does one remove the deck on a ZG222 ?
Hi I'm new on this forum so I hope this question is in the correct place. I have a 2009 Kubota zg222 that I'm going to install a mulch kit,, how do I remove the deck so I can install the kit ?
Thanks in advance..
/ Remove the deck on a ZG222 #2
Hey Jeffrey, I don't have a 222, so I'm not sure, but I simply purchased a tractor lift at Tractor supply. Lifted it high enough to really make getting the mulching kit on easily. Also helped with switching out the blades. I clean my deck frequently since we have black clay, so the lift was an invaluable purchase. I recommend one.
Hey Thanks kbuicker I looked at one yesterday and I can see how handy they would be,, I'll give it some thoughts.
Again thank You for the comeback and the info...
/ Remove the deck on a ZG222 #4
1st read your owners manual.
drop the deck to lowest setting, undo the 4 rings that hold the pins in on all 4 corners of the deck. pull the pins out, jiggle deck a bit helps. pull collar on pto shatf back and pull shaft off gearbox. lift deck links all the way up using the hydraulics and lock them up. now skid the deck out sideways.
/ Remove the deck on a ZG222 #5
I have removed the deck on my Z122r to install the mulching kit. For me I used my tractor FEL to lift the front off the ground to do some adjustments. I used a floor jack the first time. The lifting device at Tractor Supply is sold for less money at Harbour Freight who do do shipping if one isn't close.
2013 CHEVROLET SILVERADO 1500 (A67714)
2013 CHEVROLET...
2005 little wonder high output blower (A64557)
2005 little wonder...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2025 JMR Tree Boom Mini Skid Steer Attachment (A66734)
2025 JMR Tree Boom...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2015 Bombardier Evinrude 200HP Outboard Boat Motor (A66738)
2015 Bombardier...
