2 Acres half Woods and Lawn Is this B2320 for me?
   / 2 Acres half Woods and Lawn Is this B2320 for me? #81
A Kubota- all good! Now, for some photos after he gets her home, washed and waxed... right?
Thanks all. Photos will follow when I get it home around the 1st. Now I need a 3rd hand functional thing and a grapple and front and rear mount snow blowers and a cab and a box blade and a 4th function thing and maybe a 5th. Glad I saved all this money.
   / 2 Acres half Woods and Lawn Is this B2320 for me? #85
Congratulations, buying a tractor is fun and stressful at the same time, so finalizing the decision is a great step in eliminating the stress and maximizing the fun.
Well, it has been a couple weeks so I thought I owed everyone an update or rather a conclusion. After reading all the advice I decided to go with the friend's B2320 but when last I was on the forum I had not closed the deal. Long story short, it nearly fell through but in the end, my friend found the machine he needed to replace the Kubota so he put the mower deck on and drove it over for a test run.
As I wrote earlier in the thread, I have a short but steep hill that will tip my Poulan riding mower if I don't lean waaay off the edge when side-hilling to mow either side of a shallow drain ditch. We put the B in Medium and lowered the deck which when spinning is amazingly quiet compared to my little rider. Off to the hill, cheeks tight, and the Kubota stuck like glue. I got bold, strapped in and took the steepest part without leaning into the slope and again, the 4 loaded tires held on. I turned the tractor off and wrote a check.
In the end I got the tractor, 60" deck, LA 304 FEL, County Line Trailer Mover, Land Pride LR1660 rake with wheel kit, Land Pride RB1560 rear blade, a 4' Brush Hog, and a set of forks which need to be fabbed for the tractor.
I figured I'd soon be welding up some projects like a cab, the forks, and a few other ideas so I also bought the friend's Miller Passport Plus welder with 3 11 lb spools of wire, helmet, gloves, and the Miller Spoolmate 100 aluminum wire gun with a new spool. For good measure, he threw in an 80 c.f. tank of 75/25 shielding gas. A dual voltage, portable welder which cost $1800 new not including all the extra equipment cost me $950. No bat at all.
I digress.
I park the big-for-me B in the garage and take a seat and think, "What in the **** did I just do?" Did I get caught up in the pictures and videos and forum stories? Did I just spend all this money for something I don't really need just because it was on sale? Oh Lord, am I my wife?
I get the tractor Friday evening.
I'm off to a couple friends' houses to do some carpentry from 6 a.m. to 1 a.m. on Saturday and then the boys' martial arts tournament on Sunday. The check has been cashed and I have yet to get 5 minutes on the Kubota.
Get home Sunday, lawn is high, its been raining light and steady ALL day. Screw it, I'm going to mow my lawn and no better time to see how the heavy machine will treat it than during a long soak. I hop on and head out.
Rides really nice. More comfortable than I had noticed before. Sits up high - whoa! Ok, engage the mower, grind the gears, push clutch, engage the mower, "vuuummmm". Big smile. Biiiiggg smile.
Take the hills. Take tightest turn I can on wet grass, tears the sod! Shoot. That's okay though, who mows wet? Look down and see that I'm in 4WD.
Grind - feel stupid - clutch - 2WD. Let's go.
Find nice soggy area with more soil than grass and crank the wheel. Nada. No damage. Clean as a whistle. Biiiiggg smile.
Finish the 45 minute job in 20 (in the rain). Lawn looks better than ever. Cut is beautiful and with no scalping and no clumping. No more bagging!!!!!!!!!
The job is over in 20 minutes!? Hold on a minute, I just got on this thing.
Take a high speed pass down the street to wave at my fans who have braved the weather to see my magnificent contraption. Nada. Their loss.
Park it in the garage. Sit on it for 20 minutes. Go inside and stare at my lawn through the window.
Happy. Grateful.
More photos to come....
   / 2 Acres half Woods and Lawn Is this B2320 for me? #87
Avery11,
I'm glad to hear you are happy with your purchase. I really am.
But now its time for a dose of the other reality . . .you've got kids and its important that at the end of the day you come home to them. Drive a tractor in wet grass conditions on steep slopes or tricky steep sidehills is risky behavior. Sure you want to test its surefootedness . . But to take unwise risks in bad conditions is not what dad's do imo.
If you want to cut grass in the rain on flat land . . you do it if you want . . but don't get cocky . . there are too many stories of someone taking chances with their families future. . and steep wet sidehill slopes is one of them imo.
I want you to have fun with your tractor for decades and a healthy life with your kids for longer than that. Accidents happen . . No sense daring them to happen.
Jmho
   / 2 Acres half Woods and Lawn Is this B2320 for me? #88
Avery11 looks like you got a great deal on a great machine. Boys look pretty happy sitting on dads tractor. Have fun and be safe. Buyers remorse will fade quick when you start getting things done you otherwise couldn't do without it. Now it's time to enjoy it, and be proud of it. You made a good decision, happy motoring. Donnie
Axle,
I appreciate the cautionary advice. My post was meant for a little fun but perhaps I should clarify so as not to set a bad example. I had the ROPS all the way up and the seatbelt on when I tested the hill. I was moving at a snail's pace and only traveled about 10 feet at the base of the hill.
There is no more downward slope at the base; just the up slope of the ditch. I would not risk my life for my lawn that's for sure.
As a rule, I mow with the direction of a slope with only side-hilling the 10 foot run at the base that the deck bridges when I mow down hill. I'm just learning about my machine which in my opinion is valuable.
A.
   / 2 Acres half Woods and Lawn Is this B2320 for me? #90
Congratulations on your new tractor, I'm glad it is working out for you; no need to justify your actions.
"Did I just spend all this money for something I don't really need just because it was on sale? Oh Lord, am I my wife?" I doubt many of us could justify all the money we have spent on tractors and equipment, but who care.
2013 John Deere 310SK (A47384)
2013 John Deere...
Caterpillar 730 Articulated Dump Truck (A49346)
Caterpillar 730...
2000 Ford Ranger (A50515)
2000 Ford Ranger...
Kubota L503OD 50HP Utility Loader Tractor (A50322)
Kubota L503OD 50HP...
2016 FREIGHTLINER CASCADIA DAY CAB (A51222)
2016 FREIGHTLINER...
Komatsu PC490LC-11 Hydraulic Excavator (A49346)
Komatsu PC490LC-11...
