any toro groundsmaster fans on here?
   / any toro groundsmaster fans on here? #51
I didn't see this thread before. I use a 4WD Toro 455D weekly (almost daily) on our farm. We mow 20 acres out of 100 weekly. Love that mower but the 4WD sucks. If I get in a bit of mud and I'm calling for the tractor to pull me out. They are really made for golf courses. Ours has a Peugeot diesel and a 10 ft. cutting width. The Hershey Co. down the road from our farm has a larger one with a cab. Great mowers but a lot of maintenance with 3 decks all going at once.
   / any toro groundsmaster fans on here? #52
I'm not sure about that machine, but some ran an automatic over running clutch to engage the 4wd. If you dig through the parts manuals you might find a different year that was full time 4wd. It might be a simple clutch swap.
   / any toro groundsmaster fans on here? #53
A few years ago we considered a 455D, looks like a real good machine. :thumbsup:
I am sure it is very heavy for its size, that helps to get it stuck. Also turf tires don't do well in mud.
Pictures are welcome and encouraged. :D
   / any toro groundsmaster fans on here? #54
Whenever is stops raining I'll get some pictures when we dig it out of the equipment building. Looks like I'll be on it for a few days solid at this point. I'm way behind in mowing.
   / any toro groundsmaster fans on here? #55
I'm way behind also, finally amassed all the stuff for the rear tires, took the wheels off to change the tires and a couple of the bearings came out in pieces. Got the bearings, cups, seals, tires and stems all ready to go.. now to find the time to do it!
   / any toro groundsmaster fans on here? #56
Here's the promised pixs. I had some of the fleet out to put the grapple away and fit limit chains to the BX's brush hog. The Groundsmaster has a 10' cut and the 4wd is hydraulic powered on all 4 corners. Works great except for all the maintenance. It must take an hour to grease all the fittings once a week.
   / any toro groundsmaster fans on here? #57
How many lawnmowers do you need? Is that what you farm?
   / any toro groundsmaster fans on here? #58
Wow, the beast from the east! :thumbsup:
I sure like the front deck design, there are a lot of companies making them. I wonder who was the first?
I have seen some Groundsmaster 72 models for sale, from the early 1970's
   / any toro groundsmaster fans on here? #59
   / any toro groundsmaster fans on here? #60
For those that don't know what a Groundsmaster 72 is, pictures from an image search:
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
Case Ih 2388 Combine (A50514)
Case Ih 2388...
Land Honor Quick Attach Vibratory Plate Compactor (A50514)
Land Honor Quick...
2008 Genie ManLift (A50322)
2008 Genie ManLift...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
