any toro groundsmaster fans on here?
   / any toro groundsmaster fans on here? #51
I didn't see this thread before. I use a 4WD Toro 455D weekly (almost daily) on our farm. We mow 20 acres out of 100 weekly. Love that mower but the 4WD sucks. If I get in a bit of mud and I'm calling for the tractor to pull me out. They are really made for golf courses. Ours has a Peugeot diesel and a 10 ft. cutting width. The Hershey Co. down the road from our farm has a larger one with a cab. Great mowers but a lot of maintenance with 3 decks all going at once.
   / any toro groundsmaster fans on here? #52
I'm not sure about that machine, but some ran an automatic over running clutch to engage the 4wd. If you dig through the parts manuals you might find a different year that was full time 4wd. It might be a simple clutch swap.
   / any toro groundsmaster fans on here? #53
A few years ago we considered a 455D, looks like a real good machine. :thumbsup:
I am sure it is very heavy for its size, that helps to get it stuck. Also turf tires don't do well in mud.
Pictures are welcome and encouraged. :D
   / any toro groundsmaster fans on here? #54
Whenever is stops raining I'll get some pictures when we dig it out of the equipment building. Looks like I'll be on it for a few days solid at this point. I'm way behind in mowing.
   / any toro groundsmaster fans on here? #55
I'm way behind also, finally amassed all the stuff for the rear tires, took the wheels off to change the tires and a couple of the bearings came out in pieces. Got the bearings, cups, seals, tires and stems all ready to go.. now to find the time to do it!
   / any toro groundsmaster fans on here? #56
Here's the promised pixs. I had some of the fleet out to put the grapple away and fit limit chains to the BX's brush hog. The Groundsmaster has a 10' cut and the 4wd is hydraulic powered on all 4 corners. Works great except for all the maintenance. It must take an hour to grease all the fittings once a week.
   / any toro groundsmaster fans on here? #57
How many lawnmowers do you need? Is that what you farm?
   / any toro groundsmaster fans on here? #58
Wow, the beast from the east! :thumbsup:
I sure like the front deck design, there are a lot of companies making them. I wonder who was the first?
I have seen some Groundsmaster 72 models for sale, from the early 1970's
   / any toro groundsmaster fans on here? #59
   / any toro groundsmaster fans on here? #60
For those that don't know what a Groundsmaster 72 is, pictures from an image search:
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
More info coming soon! (A49346)
More info coming...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2011 FREIGHTLINER M2 TANDEM AXLE FLATBED TRUCK (A51222)
2011 FREIGHTLINER...
New Idea Manure Spreader (A50515)
New Idea Manure...
