My RX7320 is home.
   / My RX7320 is home.
My Kioti hit 100 hours yesterday. I like it a lot. My wife loves it. The last two weekends, my son in law has been operating the tractor while I use the excavator. We have been clearing several acres of land and preparing it for planting.
It has been a huge undertaking. We have a mountain of stumps.
I noticed yesterday when I started to use the tractor, that the step was bent. So I hooked a ratchet strap to it, and pulled it straight.
So far, I have not had any major issues.
I had a couple hydraulic leaks that were quickly fixed by tightening the lines.
Changing the transmission/hydraulic filters the first time was ridiculously hard. I broke two strap/chain wrenches from the auto parts store. The handle on one folded over and the other simply snapped at the weld. I ended up using a Vise-grip chain wrench. Even though I tried to fasten it as close to the base of the filter as possible, both filters were completely mangled and ruptured. I had to use my foot to press against the wrench to get it to turn.....tore a hole in my shoe, and bruised the heck out of my foot. I don't know what they are thinking at the factory when they put them on so tight. I was told by a mechanic at the dealer that they are painted on. I ran a thin blade knife around the joint hoping the cut any paint. I don't know if it worked or not.
Check the lug nuts on the tires at 10 hours and every 15-20 hours after that. I didn't and I had one work it's way lose and get stripped. I did't keep up with the tire pressure, and had a flat.
The FEL kickstand rattles terribly. I lost several nuts from that, and replaced them, and shimmed the kickstand with plastic to get the rattle out. The pins that hold the FEL on also rattle.. made a shim from a plastic water bottle to fix those and yesterday I discovered that there is a rattle from the hitch pin below the 3 point. I will be making a shim from a gatorade bottle today, to get rid of that.
This tractor is strong. I have skidded out some really large oak logs and it has done fine. I am very happy with my purchase.
And yesterday it was 86 degrees. That is pretty hot for spring. I was feeling beat down by the heat and dust early on, while running the excavator. Climbing into the air-conditioned Kioti in the afternoon to start skidding logs was a welcome break. I will be patting myself on the shoulder for getting a cab, for a long time.
   / My RX7320 is home. #92
I cut the grass the other day and was doing e same thing as it was 81 and dusty.
   / My RX7320 is home. #93
You have done a huge amount of work.
I left the fuel cap off when I left the farm last week. We had over 1.5 inches of rain. I will be draining some of the die from the filter. But I ran the tractor just the same.
My wife did a lot of work today while I was in the excavator.
   / My RX7320 is home. #95
Do you see any water in the fuel filter bowl
Looking at the engine, I saw what I believed to be the fuel filter in a black plastic container with white valve at the bottom. I was going to drain that today to remove any water that had worked thru.
   / My RX7320 is home. #97
It will work thru the entire load of fuel. I picked up a bad liar once and it meant stopping every 100 mikes and draining the fuel filter and then when I could drain no more water changing it.
   / My RX7320 is home. #98
I have a Perkins in mine with a see thru bowl at the bottom of the filter. I would drain into a clear jar and let it sit a bit and see how much water is there. Not much I bet.
It was too wet today to do very much, so I went to Crutchfield and picked up a stereo and an Adapter. Since my wife has more seat time in the tractor than me and probably will for a while, It is her Mother's day gift. She loves her music. It wasn't hard to put in with the two piece screw caps they have although, I would describe the metal sleeve that came with the Kenwood marine radio I bought, as flimsy. It works well and sounds pretty good with the stock speakers.
   / My RX7320 is home. #100
I just hit 50 hours and found my hydraulic filters to be nearly impossible to get off as well. Both filters tore, spilling fluid all over my chain wrench and me. I had to pull the rear tire off to get enough room to work... following a trip to town for a 3/4 drive ratchet set. Even with that big set, I still needed a 3' bar attached to get the wheel bolts off. Then I used the largest pair of channel locks I own and barely got those filters off.
Whew, I'm not looking forward to doing that again anytime soon. I really do like my tractor and can't wait to get in the seat again.
UNUSED MOWERKING QUICK ATTACH BOX BROOM (A51244)
UNUSED MOWERKING...
2008 Dodge Ram 1500 (A50515)
2008 Dodge Ram...
2013 Mercedes-Benz C-Class C250 (A50324)
2013 Mercedes-Benz...
2016 AUTOCAR EXPEDITOR GARBAGE TRUCK (A51243)
2016 AUTOCAR...
2013 Dodge Journey SUV (A50324)
2013 Dodge Journey...
Unused Delta Crash...
