Leveling the FEL
/ Leveling the FEL #1
roughcut
Member
NW PA
Mahindra Max 28XL hst
I have the MAX 28HST that I got about 4 years ago. The FEL has never been level and it gets very irritating when trying to get the ground work level and smooth. I have never brought this to the attention of my dealer and before I do, do any of you know how I can get it level? Looks like the clamp location on the main loader brace may be a bit different on either side and I thought about starting there. Would appreciate any advice.
Thanks,
Dave
/ Leveling the FEL #2
Inflate tires to proper spec. Park on level surface(concrete pad is best)slightly loosen FEL mounting bolts just enough to allow them to move. Start tractor,lay bucket down flat. Boom down just enough to take weight off front tires. Tighten mounting bolts. Done! :thumbsup:
/ Leveling the FEL
Thanks for responding Jabonee. I have the manual in front of me. Are you talking about the bolts that connect the back axle bracket to the Sub frame?
/ Leveling the FEL #4
The bolts hold the loader mounts (pods,uprights) to the tractor. They are the black pieces that stay on the tractor when you remove the FEL. On that set up I think there under where your feet would be if outstretched and aft on the frame. Do you have a BH on this tractor? I'll look tomorrow if I get a chance. I think I have a few on the lot.:thumbsup:
/ Leveling the FEL
Yes I have the backhoe for it also. I'll take a look for those bolts. Thanks!👍
Dexter trailer axles (A61567)
Dexter trailer...
1990 Lufkin CM-320D-305-100 Road Runner Mobile T/A Oil Field Pumpjack (A60352)
1990 Lufkin...
Bauma Light FBS752 Feller Buncher Skid Steer Attachment (A61567)
Bauma Light FBS752...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
1987 GMC C7000 Fire Truck, VIN # 1GDM7D1G3HV526472 (A61165)
1987 GMC C7000...
Wooden Wagon Wheel Rocker (A61569)
Wooden Wagon Wheel...
