How much rust can under-body spray stop?
/ How much rust can under-body spray stop?
/ How much rust can under-body spray stop? #82
Crown's YouTube video presentation, is well produced.
Though, they do incorrectly refer to front fenders as, "front quarter panels". :eek: Perhaps that's a Canadian thing, a?
Having fixed the rust, from seemingly millions of rustproofing drill holes, I would not let anyone, drill any holes, until the convinced me they have a fool proof way to seal the bare metal, they create from doing that.
Putting a little of the product around the opening, has never worked in the past, so don't fall for that.
I have had some success, with brush on window weld primer.
The problem is, the plugs fit so tightly, they push off anything you try to coat the edges of the holes with. And, the caps not only draw water, through capillary action, they also hold water there.
This problem is not as bad on a vertical surface. But, on horizontal surfaces, like rocker panels, it's really an issue.
If they still have not come up with a good solution for this, shame on them. The industry has had decades to figure it out.
/ How much rust can under-body spray stop? #83
Again, Moss' data is skewed. And your idea that Missourians might only drive on salted roads once or twice a year is ridiculous. When I was working I drove 22 miles one way on either an Interstate Hiway (I35) or a National number Hiway (69). They get salted if snow/sleet is even in the forecast. Bridges all get salted when frost is predicted. This begins in November and runs thru February. Granted it might not happen as often as it does in Michigan. But don't be na?e and think it's only once or twice a year. :)
Moss' data is skewed because the majority of State hiways in Missouri are very, very rural. They only get their snow bladed off if it's 6" or more. They only get salted at stop signs/intersections. So the data is accumulated by simple math. X number of miles of State roads. X number of tons of salt purchased. Has nothing to do with where the vast majority of Missourians drive. :)
Don't get me wrong here,,,,, I am not in any way jealous of how fast you guys can rust out a vehicle. My truck is parked in a heated shop. Never sits outside overnight. I limit my driving on salted roads every chance I get. But I still get on my knees and wash the underside of my truck thoroughly 5 or 6 times during salt season. My 16 year old truck is beginning to rust. Cab corners, rear of front fenders, nothing on rear bedsides yet. I can't wash out my cab corners or the rear of my front fenders. But I can wash out my rear bedsides. Coincidence? :)
They do the same thing in Michigan, with the minor highways only getting salted and sanded at intersections. They don't salt every time they plow and they don't salt every mile of highway.
In 2014 Michigan purchased 645,000 tons of salt for 9700 miles of state highway, or about 66 tons per hwy mile.
In 2014 Missouri purchased 220,000 tons of salt for 33,000 miles of state highway, or about 6.7 tons per hwy mile.
Michigan uses 10X the amount of salt per state highway mile on less than 1/3 the total state highway miles that Missouri does. Missouri would have to apply all 220,000 tons of its salt on only 3300 miles of its 33,000 miles of hwys to equal the salt exposure in Michigan.
/ How much rust can under-body spray stop? #84
Krown.. Without a doubt. If no crown dealer nearby check your local Mack/Volvo heavy truck dealer because Krown is OEM for their rust proofing. This is a 5gal pictured in my shop
As to how it works, I got a 1995 Toyota Tacoma, you know, the ones that rotted so bad toyota did a "recall" on them and bought many back!! Mines been Krowned since new (Ive been doining it the last several years on my own) and its rust free on the body (other than one chipped section on the wheel wells). Frame is solid too. Im sold on the product, especially if you do the "Full Monty" and let them drill your baby to access the hard to get parts around the door and sills.
/ How much rust can under-body spray stop? #85
Scoob, how do you apply it, and what would you say it is similar to, undercoating that hardens or FF?
Do you remember what a 5g bucket costs?
/ How much rust can under-body spray stop? #87
I'm in northern Ontario where they go crazy with salt on the highways, plus that liquid stuff that is even worse. I have a 1995 Ford Explorer with 500,000 KM's that I spray with Krown. I had to change the muffler, because the heat burns it off, but the shop was amazed the bolts came right out. I've never had to repair electrical or sensors, hinges or body work. I swear by it.
That's what the use on all the highway dept. plow trucks here too.
I don't have pics of the Ex on my laptop and I'm not at home, but here is my truck that has been hauling salt since new in 2013. I spray all the aluminum with Krown to keep it shiny over the winter and all the pigtails on the lights.
Look what the salt did to the black hydraulic oil tank over the winter.
Good testimony!!! Very nice Dumper!!!
/ How much rust can under-body spray stop? #88
Most of your statements above made my case. Missouri has the most miles of State maintained roadways in the Nation. I have no data to support the distribution of their winterizing materials. But rest assured, the Interstate Hiways and numbered national hiways get the vast majority. So if you are one of the unlucky ones that use those roads all the time you are constantly getting salted. If on the other hand you don't use those roads regularly you might qualify as not being exposed to much corrosive material. I would never claim that Missouri has as much hazardous weather as Michigan for example. But don't be naïve and assume Missourians are not exposed to corrosive roadways. :)
/ How much rust can under-body spray stop? #89
More great testimony. Detailed pics of the Toyota might have spoken more than a pic of the can. :)
/ How much rust can under-body spray stop? #90
And the snow/ice vary's quite a bit from northern Missouri where Richard lives from down here in extreme southern Missouri where I live. We use even less salt, and probably by a large margin. We also use beet juice down here instead of salt for a pre treatment or so I have heard. Not saying we can't have some rust problems, but I don't think it is the problem that you guys up north have or even Northern Missouri would have.
/ How much rust can under-body spray stop? #91
Definitely. I think, for Missouri, that's why the data chart that Moss posted is skewed. Missouri's corrosive treatment is used on a very, very small percentage of their total State roads.
I made a trip to Ft Leonard Wood to pick up some Hummers several years ago. They had received 12" of snow down there the night before. They were removing snow from the State Hiway with an end loader!!!!! Guess there must have been a shortage of snow removal equipment in that area?? :D
/ How much rust can under-body spray stop? #92
3m carried the same stuff. probable just like krown's. i watched the video and its no different from the way that that cars were "rustproofed" in the 80's and early 90's when some of the new car dealerships were selling a rustproofing package they installed on new cars just like krowns. this package was a big money maker for them. i'll try to remember the name of the stuff later. something "shield", just like what z-bart was doing and you see where they are today. 3m also made an interior and exterior rustproofing that is to be applied "after" body work was performed. the insurance institute also recommended this done on any body work area just like crown, but only on the repaired area.
it was also noted that this wasn't necessary on new cars because the manufactures made it not necessary because of the manufacturing process with galvanized panels, better primers and better electro-plating, and a huge difference in the paints. also most people don't know that a lot of manufactures use a closed cell foam in special places to sound deaden the car which makes it impossible to rustproof those areas and connecting areas.
it is also said "some's good, more's better, and too much is just enough".
if you do decide to to have crown's or similar done, there is a sure way to repair any plug holes they drill. just go to the store and buy some good spray primer, a color close to your car color, and a small artist paint brush.
1. remove the plug by sliding a SMALL screwdriver under the edge of the plug and into the drilled hole and pop out the plug. if the plug distorts just heat them with a hair drier or butane lighter till they go back in shape.
2. use some wax and grease remover (have to say this but rubbing alcohol works just fine) and liberally clean the hole and bare metal area.
3. shake primer and spray into the primer can cap. using the artist brush (the fuzzy end after removing from the book of a paper match stick works just as well) and coat the bare metal areas of hole and let dry.
4. shake paint can color and proceed same as above. only one or two coats, the thinner the better and let dry real good, don't rush.
5. install plug and your protected.
/ How much rust can under-body spray stop? #93
A 12 inch snow down here in Branson would be a show stopper literally. We get all excited with a 6 inch snow.
/ How much rust can under-body spray stop? #94
Ill grab a pic of my setup when im in the shop. But basically its an Arslan sprayer (sold by many companies under various names, NAPA for one). I made some custom wands to reach up inside the box sides and other places. You can buy them too, but Im cheap.
The product is similar to bulk FF when in the bucket. Very gel like. When sprayed it goes areasol and leave a fine, oily, slightly sticky film, NOT a sticky gel blob like FF does.
5gal was a couple hundred bucks ($225-250 maybe??). But that is enough to do a few cars no problem.
/ How much rust can under-body spray stop? #95
Krown doesn't seem to be anywhere near as available as Fluid Film.
I don't see where I can get a gallon of Krown. I can get one on amazon for FF.
Preference for one over the other?
Also pondering the difference between the generic "undercoat applicator" for $20 and the FF one for $90.
/ How much rust can under-body spray stop? #96
That would certainly be better than nothing.
But, it takes a lot more than a spray can primer to properly protect metal.
First, primers are much more porous than top coats. And provide very limited corrosion protection. If you have ever seen a car where someone sanded a bunch of spots and just primered them, at some point, the rust stains eventually start showing as rust comes right through every primer spot. This is because its not a good moisture barrier, by it's self.
Secondly, drill holes create very sharp edges. And, sharp edges are very difficult to build paint film up on. You can see this, by taking something like a lawn mower blade and trying to paint the sharpened edge. No matter how much paint you spray at it, it moves off the sharp edge. So, even if you carefully paint each hole, (and I have sprayed a ton of them), you still have very little film build on the sharp edge, on each side of the hole. So, you still only have a slight amount of corrosion protection.
When parts are stamped, care is taken to avoid creating sharp edges, so they don't have the same problem. They also use electrostatic spray equipment, that causes paint to be applied more evenly more.
Believe me, I have tried everything imaginable on these holes over the years.
The most effective thing I have found, which was still limited, is window weld primer. This product is designed to protect the metal under your glass, when it's glued in. 3M Single Step Primer 8682
As I said, I hope the rustproofers have found an actual solution to this problem.
If not, personally, I would not allow any holes drilled in my car.
/ How much rust can under-body spray stop? #97
This company makes inexpensive equipment to do your own undercoating, and rustproofing.
RUSFRE Undercoating Kit - TP Tools & Equipment
Rusfre Rust Proofing
I have owned one of these guns, for many years.
The gun sprays both undercoating, or rustproofing, and has a long nozzle to shoot the product deep into the panels.
Their undercoating, is by far, the best I have ever used. When it sets up, it's smooth, and shinny. Don't try to spray it through the flexible wand, you don't normally need to. Anything you can't get with just the gun, use the wand , and spray the rustproofing in side it.
A gallon of each, should do most vehicles, with some to spare.
They also make an aerosol rustproofing kit, I have not used. Rusfre Inner Panel Cavity Wax Rustproofing Kit MD 16 | eBay
When I talked to NH Oil Undercoating they said that just about every vehicle 6-7 yrs or newer had enough drain hole to get everything without drilling. Any thoughts?
/ How much rust can under-body spray stop? #99
Most of your statements above made my case. Missouri has the most miles of State maintained roadways in the Nation. I have no data to support the distribution of their winterizing materials. But rest assured, the Interstate Hiways and numbered national hiways get the vast majority. So if you are one of the unlucky ones that use those roads all the time you are constantly getting salted. If on the other hand you don't use those roads regularly you might qualify as not being exposed to much corrosive material. I would never claim that Missouri has as much hazardous weather as Michigan for example. But don't be na?e and assume Missourians are not exposed to corrosive roadways. :)
I'm not naive about it. They just don't get anywhere near the amount of exposure as Michigan. Its not even close.
/ How much rust can under-body spray stop? #100
Plus +1 moss..
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
2025 32in. Tilting Bucket Mini Excavator Attachment (A61572)
2025 32in. Tilting...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
Generac QT04854 Anax 48kW Generator (A61572)
Generac QT04854...
PALLET FORK ATTACHMENT FOR MINI SKID STEER (A61572)
PALLET FORK...
